i tried using engine degreaser (bought sa ace hardware) and soap and water. Nang malinis na saka start engine, then look where the oil leak is coming from. Kaso yung crankshaft oil seal ata, kailangan tanggalin ang timing belt cover kasi nasa likod siya ng timing belt.
maraming salamat po sa reply
mejo malakas na po leak nung sa engine ko d na kailangan linisin para makita kung san nag flo-flow... sabi ng isang mekaniko na pinag tanungan ko bka daw sa cylinder headgasket... simple lang ba pag ayus nun? kaya na ba to sa mga simpleng talyer lang?
salamt po ulit
Dudes by years of maintaining cars the usual cause of oil leak underneath is worn out C.V. oil seal, Orig part ave.price is Php250.00ea. and labor is Php250.00ea. mga 2hours rin abutin palit nyan, ipa-re-grease mo narin yung CV joints mo (CV grease is Php55ea tube) per joint consumes 5 tubes.Gudluck Dude...clone:roll::DDudes by years of maintaining cars the usual cause of oil leak underneath is worn out C.V. oil seal, Orig part ave.price is Php250.00ea. and labor is Php250.00ea. mga 2hours rin abutin palit nyan, ipa-re-grease mo narin yung CV joints mo (CV grease is Php55ea tube) per joint consumes 5 tubes.Gudluck Dude...clone
deng kung cylinder head gasket lang eh pwede na DIY na dyan. All you need is the gasket (baka mga 500) plus silicon sealant. Kung gusto mo sabay mo na rin gaskets to the sparkplugs.
