Results 1 to 10 of 11
- May 2012
- 29
June 20th, 2013 02:24 AM #194 Corolla Xe:
Manual:
Mga sir need your help, kapag aapakan ko yung gas sa 1st gear eh parang kayog-kayog, gnun din kapag nasa 2nd gear kapag mejo napadiin apak sa gas parang naaantala yung power ng makina muna lopsided sa english yata yung word ko, tapos tsaka sa mag accelerate ng ayos... ano kayang solution dito? carb. minsan napag bibintangan ko pero di ko talaga sure kung bakita ganun? tyia sa mga mag offer ng time sa prob. ko
Napansin ko kapag naka idle tapos rev ko up to 2k rpm bago umabot ng 2k yung rpm mga 1800 rpm parang nanginginig yung engine ng konti tapos parang palyado ang tunog tapos kapag lampas na ng 2k ang rpm ok na ang rev.
June 20th, 2013 08:06 AM #2
first you can do is to have a tune-up, including change of fuel filter.
second is you can have your carb cleaned.
third is you can have your fuel pump checked.
fourth is you can have your distributor and high tension wires checked.
since medyo madami dami ang kailangan gawin, have it checked by a competent shop/mechanic.
- Jun 2005
- 3,774
- May 2012
- 29
June 20th, 2013 11:06 AM #4
- May 2012
- 29
June 20th, 2013 11:12 AM #5
BANNED BANNED BANNED
- Jul 2003
- 2,267
June 20th, 2013 12:07 PM #6
- May 2012
- 29
- Mar 2013
- 139
June 24th, 2013 10:46 PM #8sir eto ginawa ko.
hard starting 13t engine at minsan namamatay kasi lunod (hazard sa daan).
check ko yung carb flooded yung barrel cause ng defective na needle valve at madumi na din yung carb mismo
pansin ko din may latak sa reservoir na parang kalawang brownish yung kulay. so ayun bumili ako ng carb repair kit (P350.00) tapos bagong fuel filter.
binabad ko yung carb sa lacquer thinner mga 3 hours sabay linis gamit toothbrush ayos na. pwerte na ang takbo.
- May 2012
- 29
July 3rd, 2013 12:22 PM #9ok na corolla ko merong binago sa mga line ng hangin sa carb. ang kaibigan kung mekaniko, di ko ma gets sinasabi niya pero ok na siya at mas tumahimik at lumakas pa ang hatak... ty mga ka tsikot sa mga comment nyo. ^_^
- Jul 2003
- 2,267
July 3rd, 2013 02:11 PM #10
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
