Results 11 to 20 of 20
October 14th, 2010 12:36 PM #11
- Jun 2007
- 135
October 14th, 2010 12:53 PM #12
October 14th, 2010 12:55 PM #13
Since I was using FS oil, every 10,000 km ang palit. kaso hindi ako nagpapalit ng oil filter every 5,000 km. tuwing change oil lang.
- Jun 2007
- 135
October 14th, 2010 01:40 PM #14
October 14th, 2010 02:36 PM #15
we got our ZZ 2nd hand. mula ng nakuha namin, nagbabawas na ito ng oil. casa maintaind naman ng 1st owner, i saw the records. ok naman. every 5,000 km palit ng oil filter tapos every 10,000 km palit ng oil. FS ang gamit mula ng 10,000 km PMS.
kung nasilip sana kaagad ang makina under the engine cover, naiwasan na tumirik ang makina.
we got the ZZ almost 3 years ago with around 78,XXX km sa odometer. bagong palit lahat ng fluids. kaso imbes na sa casa, total ang ginamit na products.
- Jun 2007
- 135
October 14th, 2010 04:03 PM #16Same tayo, got it from my aunt 2nd hand also but maintained at TM Makati every 5k PMS.
Siguro the 10,000kms oil, 5,000kms oil filter change interval did your VVTi engine some harm. Dapat talaga change oil and oil filter every 5,000kms or earlier for the VVTi engines as per what I read in the internet ah.
October 15th, 2010 05:45 PM #17
a small bucket for the the bolts, and a 10mm socket wrench with extension.
and if you want, a sparkplug remover, to clean the plugs also or replace it.
if you have a torque wrench, it may be in use also. but dont know the required torque when the bolts is put back again.
October 15th, 2010 06:16 PM #18
Stick coil (independent ignition coils) din ang Altis di ba? meron bang oil leaks sa ibabaw ng cylinder head cover? If yes, usually lumalambot yung rubber gasket ng stick coil at dito lumalabas ang oil leak.
- Jul 2009
- 31
November 18th, 2010 12:41 PM #19kung wala kang nakikitang trace ng oil sa engine mo o sa kahit saan pa walang problema yang car mo. kung sira ang cylinder head gasket nyan magbabulge ang hose mo from radiator at mababawasan ang tubig o coolant sa reservoir. Yung nangyayari sa car mo normal consumption ng oil yun, yun ngang crv ko brand new nung kinuha ko at nababawasan din kahit walang usok yun pala nung basahin ko ang manual normal kasi raw for every 1,000km it normally consumes about a liter of oil at ganun din ang sabi sa casa.
saka di mo kailangan magchange oil ng every 3000KM nagsasayang ka lang ng pera kasi recommended every 5,000km basta yung recommended na viscosity ng oil ang gamitin mo.
saka malayo sa sludge siguro
- Jun 2007
- 135
July 29th, 2011 06:33 PM #20Already had my Valve Cover Gasket replaced 2 weeks ago...medyo sira na nga and that was where the leak was coming from, that is as where we see the oil mess coming from.
Now I still see a little oil consumption on my dipstick. I'll have the oil mess on the rear of the engine cleaned with degreaser and monitor from then if there are other areas where the oil is coming from.
I went to Toyota Pasong Tamo earlier and got a qoute of 8k for labor if I have all the oil seals replaced. Plus 2k for parts I guess. the Service Advisor told me to just monitor where the oil is coming from before deciding to have all the oil seals replaced. But if budget is not an issue I could go ahead of course, he said.....he also told me that indeed oil consumption is normal as the mileage accumulates. Currently I am doing 97k kms already.
So far my spark plugs are not wet, morning white smoke on start-ups go away after a shortwhile....no burned oil odor coming from the tail pipe, no oil moisture yet as well.
So I guess the accumulating mileage is just catching-up. And normal wear and tear is taking is toll. But at least when I had the Valve Cover gasket replaced the camshafts and all are in great condition..NO SLUDGE!!!, though not as golden clean as aejhayl17's but very close, 90% as clean I guess....there is slight varnishing already but that is ok.
Xiaomi E-Car
