Results 1 to 7 of 7
    Jan 2003
    To Tsikot engine experts:
    Guys, I noticed lately that when my engine's (5K) rpm decelerates I could hear a knocking sound. It sounds like "Tick, tick, tick, tick" rather than "Tok, tok, tok, tok." What's the possible cause of this? Thanks.
    Jun 2004
    malamang ignition timing yan..try to advance..check narin loob ng distributor, gap sa contact point at air fuel mixture sa carb pag hindi efi ride mo.. at pag nag na knocking at pingning mag decelerate ka para ma iwasan stress sa mga moving parts
    happy DIY..
    Actually if you hear knock, you should retard timing, not advance further
    Mar 2005
    if you hear a knock answer it . tune up lang yan dude
    Oct 2004
    could be your fuel...might require higher octane rating. or, could be where you fill-up din, baka binabaha and may halo tubig fuel nila.
    had the same problem before...i was using shell unleaded, then i shifted to premium, then tried velocity. as advised by a fellow forumer, change brands or change stations. i changed both brand and station....solved! try mo muna ito then if it still persists, do the next step; tune up, timing, check distributor, plugs...
    Quote Originally Posted by natasatanas
    agree.
    try first the cheapest way. ;)
    Jul 2005
    possible cause- baka valve tappet clearance malaki na ang gap
Engine Knocking Sound....
