Results 1 to 9 of 9
- Mar 2009
- 5
March 10th, 2009 03:34 PM #1Mga Brad, Ask ko lang po pag tinanggal mo ba ung dipstick tpos may tumatalsik na langis ok lang ba yun? Is it normal? kasi sabi nang iba pa blow-by na daw pag ganun. Any one po please help.
March 10th, 2009 06:14 PM #2
Two things to do for proper diagnosis:
1. Check if the engine oil is at the correct level.
2. Do compression tests on all cylinders.
March 10th, 2009 06:38 PM #3
bro, natural lang na may lalabas o tatalsikan na langis pag inalis mo ang dip stick while engine is running. the same is true kung bubuksan mo ang oil cap. it's because of the pressure being build up inside the engine.
ngayon kung patay naman ang makina at inalis mo ang dip stick, hindi tatalsik ang langis but it will give you an idea how much more oil the engine has.
THE AUTO SPECIALIST
- Mar 2006
- 607
March 10th, 2009 09:06 PM #4may tester na ngayon para ma test ang engine blowby kung sobra na . it's an accurate test and no guessing .
March 11th, 2009 03:41 AM #5
Is either over full of oil, crankcase breather, pvc system are clogged up somewhere or no enough vacuum on it.
March 11th, 2009 04:34 AM #6
March 11th, 2009 09:14 AM #7
Blow by is not that negative to an engine especially pag minimal. What is bad is low compression with high blow by. Imagine your clutch master full of fluid but you cannot disengage your clutch, kasi nag "blow by" yung fluid sa seal ng plunger. Anyway, what is your mileage ang how big are the oil drops coming out?
- Mar 2009
- 5
March 11th, 2009 11:08 AM #8Thanks for the reply mga brad. hndi ko na po alam kung ilan na po ung mileage kasi po old school na yung kotse ko 1977 galant sigma po. i checked the oil level hindi po siya over sa maximum nsa level lang po sya. Pano po malalaman kung blow-by or low compression ang engine? san po pwede mag pa test. Sori po newbie lang po ako . thanks
THE AUTO SPECIALIST
- Mar 2006
- 607
March 11th, 2009 11:22 AM #9
