Originally Posted by
mames20
You could choose between the 4AF or the 4AFE engines. The 4AF engine is the 16 valve carb version of the 4AFE engine. Its less powerful (roughly 95HP) but simplier to install.
The 4AFE is common engine used in 1.6L 16v corollas. It is rated at 110HP. The problem of using this engine is you will need more parts to swap this engine into your car. You will need to change the fuel pump and make sure the engine has its EFI wiring harness complete and undamaged.
