Results 11 to 20 of 21
February 14th, 2008 05:03 PM #11
Better buy a new set of HT wires with a new distributor cap na lang. Mura lang naman bro.
- Sep 2006
- 22
February 14th, 2008 06:30 PM #12I borrowed a known good set of HT wires from a friend and installed it in my engine, still no spark is generated.
I also tested yung terminal mismo ng ignition coil (the one in a tube leading to the distributor cap then to the rotor center, also no spark was present. So the the route from the spark plugs to the high tension wires to the distributor cap being defective is eliminated.
Paano ba i-check ang windings nang igintion coil (di kasi ako familiar sa terminals ng internal na ignition coil.) TIA
Tsikot Member Rank 4
- Jun 2006
- 2,605
February 14th, 2008 08:13 PM #13better have an auto electrician check your car.
this may also help http://www.clarks-garage.com/shop-manual/ign-04.htm
February 15th, 2008 09:19 AM #14
Follow mo na lang bro suggestion ni sir userfriendly, mukhang mahirap butingtingin na kasi nag linya at ang ignition coil mismo.
February 15th, 2008 03:35 PM #15
hey bro, did you guys check if theres any power going to the Distributor?? (.5 volt reference signal) also, did you check the Igniter??
anywayz, theres a possiblity that the Distributor assembly can be faulty (which is the same on some Ignition related problems on Honda's... which is traced back to the Distributor assembly).
aite, peace.
- Apr 2007
- 20
February 16th, 2008 03:24 AM #16
- Sep 2006
- 22
February 18th, 2008 06:15 PM #17I have downloaded a manual for lancer and from there, I found a portion which deals on troubleshooting a so called power transistor using a 1.5 volt battery and an analog multimeter.
So tinest ko nga po ito by using the terminals on the distributor cap connector and from the instruction details sa manual, faulty raw ang power transistor ko.
My question is, Saan po ba located ang power transistor? Nasa loob po ba iyon ng iginition coil housing?
Gusto ko kasing ipatest sa Banawe yung part and bumili na rin kung sira nga po ito. TIA
- Sep 2006
- 22
March 6th, 2008 05:10 PM #18OK na po yung kotse ko
yun palang terminal na tinest ko yun na pala ang mismong igniter.
sira nga yung igniter nung engine ko, so punta ako ng Banawe para bumili, I got a surplus for P1400.00. Pagkakabit ayun umandar na agad.
Good thing di pa ako nakakabili ng ecu, It really pays to be kuripot sometimes
Thanks po sa lahat ng nagshare ng ideas!!!
- Feb 2008
- 325
March 7th, 2008 07:42 AM #19
