Results 11 to 16 of 16
- Nov 2010
- 98
December 20th, 2010 02:43 PM #11Right on sir. One question na lang po, is it really possible that misalligned wheels could cause that humming sound?
December 20th, 2010 09:53 PM #12
No. Misaligned tires like over positive or over negative toe and camber will produce a somewhat screeching noise like the one you get during high-speed cornering. The reason for this is because one tire or both is "scraping" the road instead of rolling freely straight ahead. You try to "correct" one side only to worsen the other and in the process, your car will wander uncontrollably from left to right and back again.
- Nov 2010
- 98
December 21st, 2010 10:36 AM #13ok sir, thanks for that piece of information. i'll be bringing the car for proper check-up just in time for the holidays. merry christmas.
- Mar 2011
- 21
June 17th, 2011 07:24 AM #14sorry to revive this thread. i have the same problem when cruising at 80kph+, may humming sound coming from the front. ano remedy sa wheel bearing? papalitan...paano? please advise. thanks.
- Jan 2005
- 445
June 20th, 2011 03:00 PM #16
