Results 1 to 8 of 8
    Nov 2006
    Mga expert pls advice naman po.After ko kasi magpalit ng timing belt and mga oil seal nagkaproblem na ko during cold start,engine dies.So every morning kailangan ko pa press ng konti ung gas pedal para di mamatay ung engine.Before di naman ganto 1 click lang sa morning and rpm is on 1.2 then back to 900 pagnormal temp na.May car is just a ae101 2E engine.Bagong palit na po ung spark plug ko.Anyone na may same experience there?thanks.
    Quote Originally Posted by three in xe View Post
    baka after na mapalitan ng TB, eh hindi nai-timing yung oto mo. pa-timing mo muna bro and check what happens.
    Jul 2006
    +1 on having timing checked and redone if necessary.
    Dec 2007
    Quote Originally Posted by mbeige View Post
    yup, kailangan i-recheck ang Ignition Timing AND make sure na naka line-up ng tama ang Camshaft and Crankshaft Gear. kasi kahit na maging off ka ng 1 tooth sa Timing Belt, mahihirapan mag start ang makina. so make sure that the Timing marks are correct.
    aite, peace.
    Nov 2003
    mybe it's just a vacuum leak problem. check the timing muna to be sure ok sya. if it is then trace if may leak.
    Sa Optra ko baliktad. Habang mainit pa ang makina at nag start, namamatay. Ano kayang sira?
    pataas mo idling mo ... i agree its either mali yung timing ng car mo or inadjust nila yung idling mo ... so check the idling
    sa optra naman pa check mo yung ignition coil mo ...
engine dies in cold start
