Results 1 to 8 of 8
- Nov 2006
- 122
April 10th, 2008 11:16 AM #1Mga expert pls advice naman po.After ko kasi magpalit ng timing belt and mga oil seal nagkaproblem na ko during cold start,engine dies.So every morning kailangan ko pa press ng konti ung gas pedal para di mamatay ung engine.Before di naman ganto 1 click lang sa morning and rpm is on 1.2 then back to 900 pagnormal temp na.May car is just a ae101 2E engine.Bagong palit na po ung spark plug ko.Anyone na may same experience there?thanks.
April 10th, 2008 11:29 AM #2
April 11th, 2008 01:48 PM #4
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 13th, 2008 03:52 AM #5mybe it's just a vacuum leak problem. check the timing muna to be sure ok sya. if it is then trace if may leak.
April 13th, 2008 02:57 PM #6
Sa Optra ko baliktad. Habang mainit pa ang makina at nag start, namamatay. Ano kayang sira?
- Sep 2007
- 215
April 13th, 2008 10:03 PM #7pataas mo idling mo ... i agree its either mali yung timing ng car mo or inadjust nila yung idling mo ... so check the idling
- Sep 2007
- 215
April 13th, 2008 10:05 PM #8
