Do you hear a buzzing sound when you turn the key to ON (not START)? In almost all gasoline cars, when you switch the ignition ON, the electric fuel pump pressurizes the fuel system and stops once the set pressure is reached. This typically takes 1-2 seconds. If the 'buzzing' takes longer, the pump may already be weak or any of the fuel filters (strainer included) may be clogged.
