Results 1 to 13 of 13
    Sep 2004
    Hi mga bro,
    May naka experience na ba sa inyo ng ganito. Medyo matagal mag crank ang engine bago mag start. Btw ang car ko nga pala is Vios 2011 E a/t. Ano ba ang dapat ko ipa check para bumalik sa dati yung condition ng car (magbilis mag start).
    TIA
    Sep 2008
    Symptoms of a faulty ignition system, could be anything like the coil, wires, etc. Best to have it tuned up by a mechanic so they can rule out and pinpoint the faulty one
    Quote Originally Posted by lancepower View Post
    Hi mga bro,
    TIA
    Aug 2013
    Hi mga bro,
    TIA
    check spark plugs, replace if needed.
    possible clogged fuel filter
    Apr 2008
    Anong klaseng prolonged cranking ba? Yung mabagal na matagal o yung mabilis na matagal? Pacheck sa electrical shop soon bago ayaw na nya magstart altogether. Culprit can be anything from starter motor, spark plugs, weak battery or faulty alternator.
    Sent from my SM-G900I using Tapatalk
    Sep 2004
    Thanks sa reply nio. Bali mabilis na crank sia na matagal mag start. Minsan naman normal yung starting nia. Re sa battery okay naman sia kasi weekly ko chineck yun using my multimeter.
    Apr 2009
    if your mileage is more than 40K km, its time to change your fuel filter. preferably OEM for trouble-free. if your battery is more than 4 years, you might as well change it too. You dont want your car to die on you at any given situation....
    May 2011
    Before replacing any parts whether time/change or regular maintenance make sure you narrow down possibilities of the symptom. Does this engine start normal just after shut down?
    Sep 2004
    Quote Originally Posted by LN106G View Post
    95,+++ kms na yun car. Nagpapa schedule na rin ako for PMS, I will mention to the SA re dun sa fuel filter. As for the battery kaka 1 year pa lang nun last February.
    Sep 2004
    Quote Originally Posted by mina_nuka View Post
    Yes, the engine start normal after shut down. Nangyayari lang talaga ung long cranking pag matagal naka park.
    Jan 2009
    Do you hear a buzzing sound when you turn the key to ON (not START)? In almost all gasoline cars, when you switch the ignition ON, the electric fuel pump pressurizes the fuel system and stops once the set pressure is reached. This typically takes 1-2 seconds. If the 'buzzing' takes longer, the pump may already be weak or any of the fuel filters (strainer included) may be clogged.
    May 2011
    your fuel system is not holding fuel pressure. the possibilities are:
    fuel injectors are leaking- this would rresult in black sooty carbon build up at the spark plug tips;
    the fuel pump check valve is no longer capable of holding pressure;
    there might be an external leak along the fuel line;
    the fuel injectors o-rings might be leaking around the fuel rail.
    the fuel cap might be restricting airflow into the tank. if this symptom happens when the weather had been hot, then there is vacuum in the fuel tank that pulls the fuel in the rail back to the tank that would result in longer time pressurizing the fuel rail.
    if you smell raw fuel around the car, that would be a result of an external fuel leak.
    Jul 2006
    We have a Vios, 2010 E/AT
    I've experienced what you just posted. But it occurs rarely (like once in a year).
    After the engine has started, it misfires, then idles up.
    Lately, I did the liberty of pulling out the spark plugs and re-gapped them. Hindi na nangyayari so far.
    It seems like the casa mechanics beforehand just installed the plugs without checking the gaps. Puro out of spec lahat.
    May 2011
    Long cranking before start up and long feed back before response, that explains it
engine cranks too long before starting
