Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Sep 2004
    Hi mga bro,
    May naka experience na ba sa inyo ng ganito. Medyo matagal mag crank ang engine bago mag start. Btw ang car ko nga pala is Vios 2011 E a/t. Ano ba ang dapat ko ipa check para bumalik sa dati yung condition ng car (magbilis mag start).
    TIA
    Sep 2008
    Symptoms of a faulty ignition system, could be anything like the coil, wires, etc. Best to have it tuned up by a mechanic so they can rule out and pinpoint the faulty one
    Quote Originally Posted by lancepower View Post
    Hi mga bro,
    TIA
    Aug 2013
    Hi mga bro,
    TIA
    check spark plugs, replace if needed.
    possible clogged fuel filter
    Apr 2008
    Anong klaseng prolonged cranking ba? Yung mabagal na matagal o yung mabilis na matagal? Pacheck sa electrical shop soon bago ayaw na nya magstart altogether. Culprit can be anything from starter motor, spark plugs, weak battery or faulty alternator.
    Sent from my SM-G900I using Tapatalk
    Sep 2004
    Thanks sa reply nio. Bali mabilis na crank sia na matagal mag start. Minsan naman normal yung starting nia. Re sa battery okay naman sia kasi weekly ko chineck yun using my multimeter.
    Apr 2009
    if your mileage is more than 40K km, its time to change your fuel filter. preferably OEM for trouble-free. if your battery is more than 4 years, you might as well change it too. You dont want your car to die on you at any given situation....
    May 2011
    Before replacing any parts whether time/change or regular maintenance make sure you narrow down possibilities of the symptom. Does this engine start normal just after shut down?
    Sep 2004
    Quote Originally Posted by LN106G View Post
    95,+++ kms na yun car. Nagpapa schedule na rin ako for PMS, I will mention to the SA re dun sa fuel filter. As for the battery kaka 1 year pa lang nun last February.
    Sep 2004
    Quote Originally Posted by mina_nuka View Post
    Yes, the engine start normal after shut down. Nangyayari lang talaga ung long cranking pag matagal naka park.
    Jan 2009
    Do you hear a buzzing sound when you turn the key to ON (not START)? In almost all gasoline cars, when you switch the ignition ON, the electric fuel pump pressurizes the fuel system and stops once the set pressure is reached. This typically takes 1-2 seconds. If the 'buzzing' takes longer, the pump may already be weak or any of the fuel filters (strainer included) may be clogged.
engine cranks too long before starting
