Results 1 to 10 of 13
March 2nd, 2017 01:42 PM #1
Hi mga bro,
May naka experience na ba sa inyo ng ganito. Medyo matagal mag crank ang engine bago mag start. Btw ang car ko nga pala is Vios 2011 E a/t. Ano ba ang dapat ko ipa check para bumalik sa dati yung condition ng car (magbilis mag start).
TIA
- Sep 2008
- 596
March 2nd, 2017 02:08 PM #2
- Aug 2013
- 475
March 2nd, 2017 04:05 PM #3
- Apr 2008
- 6,235
March 2nd, 2017 04:34 PM #4Anong klaseng prolonged cranking ba? Yung mabagal na matagal o yung mabilis na matagal? Pacheck sa electrical shop soon bago ayaw na nya magstart altogether. Culprit can be anything from starter motor, spark plugs, weak battery or faulty alternator.
Sent from my SM-G900I using Tapatalk
March 2nd, 2017 05:41 PM #5
Thanks sa reply nio. Bali mabilis na crank sia na matagal mag start. Minsan naman normal yung starting nia. Re sa battery okay naman sia kasi weekly ko chineck yun using my multimeter.
- Apr 2009
- 429
March 2nd, 2017 07:24 PM #6
- May 2011
- 481
March 2nd, 2017 07:56 PM #7Before replacing any parts whether time/change or regular maintenance make sure you narrow down possibilities of the symptom. Does this engine start normal just after shut down?
March 3rd, 2017 11:33 AM #8
March 3rd, 2017 11:35 AM #9
March 3rd, 2017 12:02 PM #10
Do you hear a buzzing sound when you turn the key to ON (not START)? In almost all gasoline cars, when you switch the ignition ON, the electric fuel pump pressurizes the fuel system and stops once the set pressure is reached. This typically takes 1-2 seconds. If the 'buzzing' takes longer, the pump may already be weak or any of the fuel filters (strainer included) may be clogged.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
