Results 1 to 9 of 9
- Oct 2004
- 278
June 24th, 2005 04:31 AM #1Hi. It's just my first time to take care of a diesel engine vehicle...
I have an FX with 2c-t engine....
At first, it really runs very well.. smooth acceration. I usually change my change my oil/filter 4-5T kms... between 6mos to 12mos fuel filter change.
Now, I'm noticing that i'm lacking torque, especially whenever I have a number of people on board. I also just get around 7.5kms/L on city driving.
It's been just about 4000kms since I last had my calibration/nozzle replacement.
What seems to be the problem? I'm monitoring the oil level, but it seems ok... I'm loosing some but on a very minimal level, which I believe mo be normal.
Could it be that I already need valve clearance adjustments (which I honestly can't remember when I had it last checked)? What other things do I need to check?
Can you guys recommend a good shop preferably Makati area...
- Oct 2004
- 278
June 24th, 2005 04:42 AM #2Hi. It's just my first time to take care of a diesel engine vehicle...
June 24th, 2005 09:42 AM #4
Have you cleaned the air filters as well? If it's a turbo, you can try to have it checked also (especially if you got the engine surplus, and also if you don't allow cool down time before shutting the engine off).
June 24th, 2005 09:59 AM #5
check fuel filter, air filter, adjust tappets to specs... that's in order of priority. most of time, dirty or clogged fuel filter lang ganyan in my (limited) experience.
June 24th, 2005 12:43 PM #6
Barado filters ng injection pump. It could be caused by different gas stations you've been filling up with.
June 24th, 2005 07:29 PM #7
sabi nila di na daw na-aajust ang valve clearance ng makinang ito(2c-t)..makina itself is disposable...
how true is this?baka urban legend nalang ito...
- Oct 2004
- 278
June 24th, 2005 10:11 PM #8well, my air filter is OK, fuel filter last changed nung march lang...
I don't think cooling down the engine after running is required for 2c-t engine... for what i've noticed, not like other turbo engines which are just oil cooled, 2c-t is both oil and water cooled.
I'm really suspecting the valve clearance, or probably my valve seals.... The last time I tried to take off the injectors, one has some oil...
June 26th, 2005 12:28 PM #9Originally Posted by alwayz_yummy
From what was shared by an acquaintance who used to have a MEGA-Taxi (read: first-gen FX) fleet, he had one mechanic who formerly worked with toyota (kaya raw kabisado niya ang mga ito) who did it for three of his FX. Ang ginagawa raw was take off the head and manually grind the valve into the valve seat para mag-seal properly. Gumamit daw ng grinding compound (yung green) tapos may suction tool (yung parang nasa mga windshield shades) na may stem. The valve is attched to the tool, some grinding compound is applied to the valve seat, and the valve itself is ground on the seat, parang nagbabati ka ng tablea...
Then after the seat is ground, yung valve stem naman is ground to shorten it para hindi na ito tumukod.
Puwede siguro gapang ang wire sa space ng rear hatch lifter/struts papunta sa rear bumper, tapos...
