Results 21 to 23 of 23
February 17th, 2009 09:21 AM #21
Here are a few more troubleshooting tips for you to chew on. :D
http://www.aa1car.com/library/vacleak.htm
THE AUTO SPECIALIST
- Mar 2006
- 607
February 17th, 2009 09:45 AM #22scanner is also recommended to innitially check the system through live data if it's OBD CONNECTOR EQUIPPED.
- Feb 2008
- 577
February 18th, 2009 03:07 PM #23i'm using carb engine so no electronic diagnostics... too bad.
anyway, i've isolated the problem and i found out that my vacuum diaphram (for the a/c idle up) is busted. the vacuum switch transfers manifold vacuum, but once the a/c disengages, the diaphragm fails to retract, thus still high idle.
its like this... http://i264.photobucket.com/albums/i...IMG_1521sl.jpg
meron ba nakakita ng ganito sa inyo? i need this one replaced for proper a/c disengagement else very low idle (400-600)... patay makina
Xiaomi E-Car
