Results 1 to 9 of 9
  1. #1
    Hi all. Sorry kung na-discuss na ito in another thread, pero I can't find anything about the topic using the search function.
    Anyway, paano po ba nililinisan ang sparkplugs? dry brush lang ba (e.g. toothbrush)? or ibabad sa kerosine? gas? alcohol? or meron ba cleaning chemical for sparkplugs talaga?
    How often do you do it? every 5000kms, sabay lang sa change oil?
    Sep 2006
    I use a Bosch hot air blower. It does a good job of burning out all the oil and fuel deposits on the plugs.
  3. #3
    sir, is this the same as a heat gun?
    Aug 2007
    got it from the net, i hope it would help
    Prepare the materials:
    Spark Plug Socket wrench
    Sandpaper #1500 for Spark Plug
    Thin tipped knife or pointed tool.
    Bristle Brush
    Make sure your engine has rested after an hour or so, to avoid burns.
    The Spark Plug is hot after using your car, let it cool first.
    Pull the Spark Plug Collar.
    Using the Spark Plug Wrench, twist counter clockwise to loosen the spark plug.
    Spark Plug, up close & personal.
    Using a pointed tool, scrape off carbon residues on the plug’s tip to reveal the probe.
    Using a Sandpaper #1500, sand the probe gap.
    Check the gap if a flat screw driver’s tip can fit in between.
    Hammer it down to close in the gap or separate if it is too close.
    Bristle brush or blow the dust & dirt off the spark plug.
    Return and screw it.
    Tighten it using a Spark Plug Wrench, Not too tight!
    A ¼ arch will do the trick.
    Snap the high tension wire collar to the plug’s end.
    http://www.expertvillage.com/video/6...s-cleaning.htm
    Jul 2003
    before, i would use sandpaper to clean the sparkplugs.
    now, i use steel brush.
    Jan 2008
    sandpaper, kerosene, tiny knife (or similar), small steel brush & rags.
    make sure tama yung gap before putting it back.
DIY sparkplug cleaning - paano?
