Originally Posted by
Chef Noob
*Meledson - Try building one for it na!...Its not as hard as it looks.
*Kinyo - Where did you get the CDI layout sir? Does it have the multi-spark feature?
*Sirkosero - Thanks for the heads-up sir. Actually, I did notice the coil heating up more than usual.
Also, I do see a slight flaw in the design layout. It indicated there to bypass the ballast resistor(rated at 1.5ohms) found on the positive side of the coil. Although they added a resistor in the circuit, it only had 0.5ohms resistance & 5 watts output. This in effect, increases the current & voltage passing through the coil - giving you a bad ass spark, but pushes your coil to its limits.
The thing about ignition coils; even though it is installed in a 12volt system...it is meant to run on only 6 volts of power.(If it was made to run at 12 volts, then you wont be able to start your car since the starter eats up half of the current)...
Based on my observations, there are three ways to remedy this.
1. change the resistor in the module with one that has 1.5ohms rating.
2. Replace it with a heavy duty ignition coil.(the red Bosch coil will work just fine)
3. DO NOT bypass the ballast resistor.
For me, after noticing the heat being produced by my stock coil, I did the 3rd option. It did decrease the power output of my engine just a little bit, but made my coil cooler. I do plan to install a Bosch unit though, so I can take advantage of the added power given by the module.
How to tell if your coil is running more current than it should?
Step 1. Get a multitester or Volt meter and set it to DC. If using digital, set the max voltage to 20V.
Step 2. Hook up the positive needle to the + of the coil. Hook up the neg needle to the (-) of the coil.
Step 3. Turn ignition to ON position. It SHOULD read more or less 6V.
Step 4. Start the engine. Slowly rev the engine and watch the meter. It should rise up to 9V while your revving up the engine. If it reads more than that, your coil is biting off more than it could chew.
Do keep in mind, ignition coils are able to withstand harsh currents. They are made that way. However, it still comes down to how well each coil is made. Meaning, quality coils will be more durable while cheap ones will burn easily.
NOTE:
When acquiring Bosch coils, try to get the red one since the blue one has a resistor already built in the unit.
