Results 1 to 20 of 20
    Jun 2013
    Anyone tried using products like Gumout or CRC intake valve cleaner? I'm nearing 20k Km and I'm thinking of ordering and using the Gumout intake valve cleaner to spray and clean some of the carbon deposits for maintenance. Just want to know if any tried using these kind of products and had issues with it.
    BTW the car has gas turbo direct injection.
    i have never had it done on our car.
    we just do the italian tune-up. it's also more delicious.
    Jun 2013
    I also do that once in a while. Extremely fun.
    But I'm thinking.. maybe its not enough. Wala pa akong alam na shop na nagtatanggal ng carbon deposits dito sa Pinas. And the carbon deposit issue on intake valves of DI engines is real and inevitable...
    Aug 2017
    Try GDR Technics
    72 Shorthorn, Project 8
    0922 878 1527
    Please mention that I recommended them 😊
    doc, even if you do the italian tune up on a DI engine. it wont help as the injectors are past the intake valves. Toyotas and some fords have dual injection (port and direct injection)to fixed this issue. while some hyundais&kias have gone back to port injection instead of GDI(direct injection).
    Jun 2013
    That is true. Fuel won't reach the back of the intake valves, therefore there won't be anything to clean it.
    The theory behind italian tune up for DI as I recall, is that "supposedly" you run the engine hard long enough so that the engine produces enough heat to melt the carbon deposits off. I'm not entirely convinced that its enough or it even works at all.
    ah yes driving 5000rpm for an extended period.. but how for long? maybe get a USB boroscope? see how it looks before and after?
    They'll help, won't be thorough, & would risk fouling plugs. If you want the proper intake cleaning....walnut blasting is the way to go. You'll need make/model specific blasting equipment & adapters.
    i don't know.
    i've never had our car "cleaned" in any other way.
    and as far as i know, the engine still works fine.
    what about techron?
    i don't know.
    what about techron?
    Techron works fine in port injected engines, does nothing in DI intakes, doc.
    Reviving this thread. Anybody know where I can find CRC intake valve cleaner?
    It's out of stock in both Lazada and Shopee.
    International shipping restrictions regarding flammable items rules out purchasing from Ebay and Amazon.
    I plan to use it to clean the intake valves every 10k kms. As, I don't think anybody will be offering walnut blasting in the near future.
    As of now, Seafoam Top Engine cleaner is the only one available on Lazada and Shopee. But, the reviews on that product is not that good.
    ^ try mo sa handyman do it best. i've seen several crc products there
    Jun 2013
    I highly doubt shops offer walnut blasting in the Philippines, especially here in Mindanao.
    Parang wala pa ata masyadong awareness ang mga tao sa ganitong issue ng mga DI engines dito sa Pinas as evidenced by the lack of discussion in forums and solutions offered by shops. Frankly, it is quite worrying since many cars now are using gasoline DI...
    Would like to but I’m afraid I don’t have the best of knowledge and expertise on how to test it. Sana yung topgear or other motor journalists mag experiment ng ganun.
    It's part of the service menu of a known tuner, sir. Equipments, all from the US. The market may still be in its infancy. This service will be more appreciated when current DI engines age & start seeing build-up issues. Another planned service will be for diesel engines w/ DPF. Stay tuned.
    Jun 2013
    Maybe and hopefully shops would offer cleaning intake valves soon. But it might be an expensive service since its quite new.
    That’s why I think there should be some sort of maintenance to prevent or slow down the carbon deposits like spraying intake valve cleaners but as you said, not the safest method..
    Installing an Oil Catch Can may help. It just adds 1 more item to monitor & do periodic DIY draining.
    The walnut procedure is pretty involved & is preferably professionally done. It totally reverses the effects of build-up. In Europe & the US, you'll see it a standard service premium badge dealerships offer for their DI engines.
    Waiting for that. Who is the tuner?
    Quote Originally Posted by istan View Post
    They're currently in discussions w/ certain marks. Let's await their word on service's official introduction.
Direct Injection carbon intake valve cleaning
