Results 21 to 27 of 27
- Oct 2004
- 278
February 14th, 2015 11:24 AM #21Kung i-cocompare yung oil seals na OEM by NOK sa replacement NOK, malaki difference.
OEM NOK - brown yung oil seals (better heat resistance, matagal lumutong)
replacement NOK - black oil yung oil seals
Sa case ng NOK valve seals, OEM & replacement tend to have the same appearance (black)... pero yung OEM mas pulido ang gilid-gilid.
AFAIK, yung mga vacuum sealed ay mga replacement other brands... yung OEM naka-box at pwede ngang mapalitan ang laman... so yan ang mahirap ma-identify kung OEM nga ang laman lahat.
- Jul 2010
- 570
February 14th, 2015 01:20 PM #222 klase nga yun NOK Valve Seal mabili sa Banawe.
Dati yun NOK kulay brown binili kasi P35.00 each lang. Pero after 2 yrs ay nag leak uli yun engine ko. Kahit hindi nag overheat ang engine.
So, yun huling diy TOH ko ay NOK kulay green in-install ko P75.00 each. Orig daw yun sabi ng binilhan ko.Last edited by Chinoi; February 14th, 2015 at 02:12 PM.
February 17th, 2015 08:43 AM #23
Duly noted mga tips nyo bros... Thanks. Bibilhin ko na bago mag Friday para maipakabit na rin by Saturday
- Jan 2015
- 468
February 17th, 2015 10:13 AM #24^^^nakabili na ako, and settled sa OEM ibanh iba itsura ng Nok lang sa honda OEM na Nok din.
February 23rd, 2015 12:40 PM #25
Finally had the top overhaul done last Saturday. Kinuha ko na yung tig 180 each
Ito itsura nung ilalim mabaklas ang head. Yung 8 old seals bumigay yung life span 3 years lang.
Sent from my Windows Phone 8 using Tapatalk
- Jan 2015
- 468
