Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
    Oct 2004
    #21
    Quote Originally Posted by kimbon View Post
    bro clarify ko lang to medyo di lang clear eh.. are you comparing the OEM vs non OEM the qualities.
    +1 here. make sure to buy the vacuum sealed packaging instead. some brands have their logo/company name printed mark on the gasket itself.
    Kung i-cocompare yung oil seals na OEM by NOK sa replacement NOK, malaki difference.
    OEM NOK - brown yung oil seals (better heat resistance, matagal lumutong)
    replacement NOK - black oil yung oil seals
    Sa case ng NOK valve seals, OEM & replacement tend to have the same appearance (black)... pero yung OEM mas pulido ang gilid-gilid.
    AFAIK, yung mga vacuum sealed ay mga replacement other brands... yung OEM naka-box at pwede ngang mapalitan ang laman... so yan ang mahirap ma-identify kung OEM nga ang laman lahat.
    Jul 2010
    #22
    2 klase nga yun NOK Valve Seal mabili sa Banawe.
    Dati yun NOK kulay brown binili kasi P35.00 each lang. Pero after 2 yrs ay nag leak uli yun engine ko. Kahit hindi nag overheat ang engine.
    So, yun huling diy TOH ko ay NOK kulay green in-install ko P75.00 each. Orig daw yun sabi ng binilhan ko.
    Sep 2012
    #23
    Duly noted mga tips nyo bros... Thanks. Bibilhin ko na bago mag Friday para maipakabit na rin by Saturday
    #24
    ^^^nakabili na ako, and settled sa OEM ibanh iba itsura ng Nok lang sa honda OEM na Nok din.
    Sep 2012
    #25
    Finally had the top overhaul done last Saturday. Kinuha ko na yung tig 180 each
    Ito itsura nung ilalim mabaklas ang head. Yung 8 old seals bumigay yung life span 3 years lang.
    Sent from my Windows Phone 8 using Tapatalk
    #26
    ^^^good job, sir. I also finished mine last tuesday eh. Heheheh.
    Sep 2012
    #27
    Hehe thanks... Congrats din sa yo
Dilemna on NOK Valve Seal
