Results 1 to 10 of 25
- Mar 2011
- 161
March 28th, 2012 01:08 PM #1question po, kanina nag pa gas ako, (toyota corolla) napasin ko diesel ang kinarga buti 13 pesos pa lang 0.29li. kinausap ko supervisor, mahahalo lang daw yun matutunaw daw sa gasoline yun kasi sobrang konte lang. medyo nagmamadali din ako kaya hindi ko na pina drain. sabi naman nya pag nagkaproblem within the day ibalik ko daw. nakauwi naman ako ng maayos. anyway ok lang kaya yun? or may long term effect pa yun? need ko ba stay on yung engine ko para makita ko kung mamatay or ok na yun?
thanks!
March 28th, 2012 01:22 PM #2
yup, it's the other way around Ang mas sakit Sa ulo...diesel engine nakargshsn ng gas..wait didi get it right or Ito yun mas masama
- Mar 2011
- 161
March 28th, 2012 01:35 PM #4
March 28th, 2012 01:50 PM #5
Diesel's specific gravity is 0.82 to 0.95. Gasoline's specific gravity is 0.71–0.77. Basing from the SG, diesel stays at the bottom. Gas on top. Correct me if i'm wrong but the two are miscible.
Octane rating is lowered so there is a possibility of knocking.
Volatility is also lowered. Fuel will not vaporize easily.
Diesel in a Gas engine is actually not bad when done in a small ratio but straight Diesel will not burn properly in a Gas engine. but it still depends on the ratio of diesel to gas. ilan liters ba gasoline pinakarga mo tsaka carbureted ba or fuel injected tsikot mo?
March 28th, 2012 01:50 PM #6
hindi ba mas malaki ang nozzle ng diesel at ito ay hindi kasya sa opening ng gas tank?
- Mar 2011
- 161
March 28th, 2012 01:54 PM #7
- Mar 2011
- 161
March 28th, 2012 01:55 PM #8
March 28th, 2012 02:13 PM #9
Tama ka riyan bro.,- diesel sa gas na sasakyan,- the worst thing that could happen ay itirik ka lang... and then, i-drain mo ang buong tangke... Pero, gas sa diesel na sasakyan,- puwedeng sirain ang walls ng makina mo. Remember,- walang spark plugs ang diesel na makina,- kaya pressure at temperature ang pang-ignite ng fuel...- kaya dapat- i-drain kaagad....
Sa ibang bansa iyan, katulad ng Amerika bro.,- hindi rito sa Pilipinas....
15.2K:froggy:
Xiaomi E-Car
