Results 1 to 10 of 2348
    Aug 2011
    need help po with my L300FB i cant
    start it eh, nagcracrank naman siya.
    already replaced the fuel filter,
    cleaned the air filter too, napaltan na
    rin battery but still ayaw parin
    magstart. is it possible that there is a
    problem with fuel injection ayaw kc
    magpump ung fuel filter
    Sep 2006
    Quote Originally Posted by laronde View Post
    1) The hoses on your fuel filter may have been connected the opposite way? There is a one way valve in the filter base.
    2) You may have a suction leak?
    3) Absence of +12 volts to the injection pump solenoid or a failed solenoid coil?
    4) Faulty injection pump.
    Aug 2011
    Quote Originally Posted by Dieseldude View Post
    thanx sir pinatingnan po namin knina sa mekaniko sabi wala raw pumapasok na kuryente sa glowplugs? kaya hindi makapagpreheat at ang result. ayaw magstart. thanx sa advise
    Sep 2006
    Yan yung recommended fix kasi sabi mo ayaw mag pump ng fuel.
    Pa-check mo ang wiring, glow plug relay, or preheat controller kung walang kuryente sa plugs.
    Good luck.
Diesel Fuel Injection System Help Desk
