Results 821 to 830 of 2348
- Apr 2005
- 73
January 5th, 2010 11:01 PM #821
- Jan 2010
- 8
January 6th, 2010 04:33 PM #822HI sir, I own an L400 spacegear and its been working well. My question is not with my vehicle but what I saw with the new adventure. I saw the injection pump has this thing, as i really don't know what it was na nakakabit sa side ng injection pump. mayoon syang nkakabit na hose coming from the cooling system which means from the side of the engine to the injection pump. Can you tell me sir Dieseldude kung para saan ito. Does it has to do with putting the fuel temperature higher so it will burn effeciently and have alesser emission of smoke?
Thanks in advance.
- Sep 2006
- 1,335
January 7th, 2010 08:03 PM #823
- Sep 2006
- 1,335
January 7th, 2010 08:05 PM #824
- Sep 2006
- 1,335
January 7th, 2010 08:09 PM #825
- Sep 2006
- 1,335
January 7th, 2010 08:18 PM #826
- Sep 2006
- 1,335
January 7th, 2010 08:28 PM #827Hindi ako familiar sa L400 Spacegear, pero gets ko ang tinatanong mo.
This is a cold idle device, a thermal capsule which expands when water heats it. When the engine is cold, timing is advanced and idle rpm is higher than normal. As coolant temp increases, this capsule moves a lever either to retard timing a bit, or lower the idle speed, or do both functions.
January 8th, 2010 01:01 PM #828
nakow! ganon ba? greenish talaga siya nung isinalin namin sa black container... ginawa ko to noong nagiipitan ng diesel dito sa amin. kaya after karga sa L300 drain agad tapos salin sa container pagdating sa bahay.. 500 petot lang kasi ang max na pakarga bawat station..
sayang 40liters pa naman... dibale pang hugas hugas na lang..
maraming salamat sir!
- Jul 2008
- 935
January 10th, 2010 02:20 AM #829Hi Dieseldude...
May tanong ulet ako...although hindi ito about sa diesel engine kungdi ito ay tungkol sa transmission ng diesel engine ko...kahit pano konektado pa rin...hehehe...
1KZ-TE yung engine ko at A/T(Hi-ace van, subic),,,ilang liters ng ATF kaya yung kailangan ko para sa change-oil ng tranny ko..? tsaka pano ba talaga mag-check ng tamang oil level ng tranny, may nakikita kasi ako na hot and cold e? Tinesting ko na rin nung cold pa siya mataas yung oil abot sa hot, nung pinaandar ko na ng mga 5mins at konting andar tas check ko ulet yung oil level nasa cold naman...aysus! Hindi ko malaman kung baliktad o anuman...Tsaka ano nga pala yung magandang ATF yung marerecommend nyo? RP ATf?
TIA ulet ng marami...
- Sep 2006
- 1,335
January 10th, 2010 10:05 AM #830Hi Dieseldude...
May tanong ulet ako...although hindi ito about sa diesel engine kungdi ito ay tungkol sa transmission ng diesel engine ko...kahit pano konektado pa rin...hehehe... Wala akong info jan pero try kita tulungan. Pwede ka din mag tanong sa Tsikot transmission forum.
1KZ-TE yung engine ko at A/T(Hi-ace van, subic),,,ilang liters ng ATF kaya yung kailangan ko para sa change-oil ng tranny ko..? Hindi ko alam.
tsaka pano ba talaga mag-check ng tamang oil level ng tranny, may nakikita kasi ako na hot and cold e? Oil expands when hot kaya may hot and cold markers ang dipstick.
Tinesting ko na rin nung cold pa siya mataas yung oil abot sa hot, nung pinaandar ko na ng mga 5mins at konting andar tas check ko ulet yung oil level nasa cold naman...aysus! Hindi ko malaman kung baliktad o anuman... Nag circulate na ang transmission oil mo kaya bumaba sa "cold" level. Aakyat ulit yan sa hot level kung mag wait ka mga 10 minutes with engine off. Hindi iinit ang transmission oil sa 5 mins engine run.....kelangan i-drive mo ang van with load.....approx. 30 mins. Malamang lalampas ka sa "hot" level".
Tsaka ano nga pala yung magandang ATF yung marerecommend nyo? RP ATf? Hindi ko din alam. Petron, Shell, Caltex have good ATFs. Pero dapat alam mo ang oil grade...... So try Tsikot transmission forum.
TIA ulet ng marami... You're welcome.
This is a bobo to MMC. Mirage has good sales, sayang benta nila dyan.
Mitsubishi Philippines
