Results 1 to 6 of 6
- Feb 2008
- 577
October 17th, 2009 08:01 AM #1Hi,
I quite new to the world of diesels and I got a few questions in mind:
1 - Is there a non-electronic turbo diesel engine?
2 - If the alternator and battery is disconnected after the diesel engine has warmed up, will it still continue to run?
October 17th, 2009 10:14 AM #2
Yes, more than there is electronic turbo diesels.
Electronically controlled diesel have ECU, sensors and actuators that depend on electricity, these componenets is vital to the operation of the engine.
But I heard of instances/emergencies that an electronic controlled diesel engine cannot be shut off even if these batteries where disconnected.
- Feb 2008
- 577
October 17th, 2009 10:29 AM #3thanks,
as for the first question, its good to here that there are non-electronic turbo diesels. can you name any engines that are locally available?
as for my second question, i was only referring to non-electronic diesels.
now to re-phrase my question,
if the alternator and battery is disconnected after a non-electronic diesel (turbo or non-turbo) engine has warmed up, will it still continue to run and make the vehicle move w/o any electrical/electronic parts turned on?
October 17th, 2009 10:57 AM #4
Most locally sold diesel before 2000 where non electronic. You have 2L of Toyota 4d56 of the Mits the 4ja1 of isuzu are the more popular.
Non electronic diesel still needs its fuel solenoid valve energized. If not fuel will not pass through.
- Feb 2008
- 577
October 17th, 2009 07:19 PM #5is that solenoid valve similar to the fuel cut off valve in a carburetor for gas?
in any case, any idea how much those non-electronic turbo engines cost (surplus) plus a 4wd tranny?
October 18th, 2009 09:44 PM #6
similar in function.
It will depend on the displacement and the chassis where you put it.
Old school non electronic diesels are reliable and easier to repair and diagnose but less powerful and efficient. If you plan a Japan surplus engine be sure the engine was sold locally so you can source parts.
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
