Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Jan 2004
    guys, tips naman dyan o. kasi i have this habit na pinapa-init muna yung engine ng dmax before i start to drive away. talaga bang ganun ang mga diesel lalo na yung mga may turbo?
    thanks!
    May 2004
    IMO, di na dapat (yung luma lang yun). just drive normal(wag birit ha), dun muna sya papainitin habang tumatakbo ng tama lang.
    Jan 2004
    thanks. sabi kasi manual e.
    Jun 2004
    After starting the engine, allow engine idle it self, avoid revving, allow OIL/lubricant to circulate for a few second then drive moderately>>
    Jun 2004
    As i observe most drivers/owners REV engine after SHUT DOWN>>
    Shaft bearing and others migth wearout sooner than normal>>
    Avoid revving when turning OFF the engine
    allow normal idle for few sec specially for TURBOS & SUPERCHARGER>>
    ian_rex
    tama naman yun eh.. pag ka istart nang sasakyan you need the OIL PUMP to circulate the oil to the engine.. though mayroon siyang coating pero still kahit mga 30secs ok na yan.. pag nawala na ang OIL PUMP indicator light pwede na yun pero as such 30 sec. tsaka don't rev bigla slowly but surely
    as to turning off.. tama si boss JAYArc na wag revolution sabay off ginagamit lang ito sa carbureator type hehehehehe
    Jan 2004
    yep sir. di ko naman ginagawa yung rev bago killing the engine. in my experience with gas engines masama ito kasi mas nakakalusot na gas past the piston rings whih is very bad dahil natatanggal yung lube.
    thanks!
    pansin ko lang with my xwind wala yung heater indicator nya sa console yung parang coil ang itsura. before kse with my toyota hilux meron e. bakit kaya?
    Dec 2002
    better kung pina-painit but of course you can drive straight basta hindi birit
    May 2004
    Sir, wala na yata nun sa direct injection engine.
Diesel Engine question
