guys, tips naman dyan o. kasi i have this habit na pinapa-init muna yung engine ng dmax before i start to drive away. talaga bang ganun ang mga diesel lalo na yung mga may turbo?
tama naman yun eh.. pag ka istart nang sasakyan you need the OIL PUMP to circulate the oil to the engine.. though mayroon siyang coating pero still kahit mga 30secs ok na yan.. pag nawala na ang OIL PUMP indicator light pwede na yun pero as such 30 sec. tsaka don't rev bigla slowly but surely
as to turning off.. tama si boss JAYArc na wag revolution sabay off ginagamit lang ito sa carbureator type hehehehehe
yep sir. di ko naman ginagawa yung rev bago killing the engine. in my experience with gas engines masama ito kasi mas nakakalusot na gas past the piston rings whih is very bad dahil natatanggal yung lube.
pansin ko lang with my xwind wala yung heater indicator nya sa console yung parang coil ang itsura. before kse with my toyota hilux meron e. bakit kaya?
Originally posted by Leon275 pansin ko lang with my xwind wala yung heater indicator nya sa console yung parang coil ang itsura. before kse with my toyota hilux meron e. bakit kaya?
Turbo A/T ang Crosswind ko. Advise sa akin ng karamihan is to:
WARM-UP after starting. Pag nakita ko na umaangat na yung temp indicator, pwede ko na sya i-DRIVE.
COOL DOWN after a long trip and/or a fast drive. 2 minutes is enough. The turbo mechanism's speed is much much faster than that of the engine kaya if engine is turned OFF kaagad, turbo will run without oil and masisisra.
This is what I understood from the gurus here at tsikot. Correct me please kung meron mali.
letting the engine idle to normal operating temp just wastes fuel. you can drive away immediately upon starting the engine without any adverse effect, just keep the revs down until then. this has the added effect of warming up not just the engine, but also the transmission and the differentials and other parts, and warm-up will be faster like this than idling.
