Quote Originally Posted by FrankDrebin
Ride is 2001 Isuzu Higlander POWER XTRM TRM TRM ala Centurions the cartoons hehehe
Expenses every 5K (DIY)
4 liters Delo Gold MultiGrade = Php550 (Much cheaper if I use the Delo Silver)
Oil Filter = Php250 (Nakalimutan ko lang yung exact)
Fuel Filter = Php150
Fuel Mileage = 10-12km/lt
Simple Suspension Setup but sturdy enough for Phil Road Condition. No regular replacement of stabilizer like that of any sort. And also parts are much cheaper.
OT
frank, ano fuel filter mo? ang mura kasi. sakin VIC oil and fuel filtersdin, parehong P220 each. C-512 for the oil filter, FC-208A for the fuel filter.
caltex delo din ako although minsan, castrol CRDplus or Petron Rev-ex trekker. da best so far caltex delo and rev-x trekker in my experience.
back on topic,
maintenance-wise; sa diesel ako, fluids and filters lang; sa gasoline, you also have to check the electricals, specially those related to the fuel ignition system - for old school gas ; ignition coil; spark plugs, high tension wire, contact point, distributor, battery..andami. hirap mag trouble shoot minsan pag nagloloko makina mo. andyan pa yung carburador, fuel pump.
maganda lang sa gasoline, madali iadjust yung ignition timing..konting ikot lang ng distributor ayos na. altho for newer gas engines, admittedly marami nabawas sa mga checklist na to.
