Page 1 of 3 123 LastLast
Results 1 to 20 of 74
    Sep 2013
    Reliability
    Maintenance
    Cost
    Etc po
    And mas mura naman po diesel bat karamihan gas type ang ginagawa po o kaya puro gas type dinadala sa pinas.. Newbie po
    Quote Originally Posted by Ciz View Post
    Reliability
    Maintenance
    Cost
    Etc po
    hindi naman... maraming diesel din..
    diesel engines are more expensive to manufacture. thus, diesel vehicles are more expensive in the showroom.
    diesel engines generally spew out more pollution than gas engines. environment-conscious buyers shun diesels.
    diesel engines vibrate more, are noisier, generate more heat, and are generally slower than gas.. thus, many private buyers shun diesels.
    maintenance? it's debate-able..
    about the only thing cheap in diesels, is its fuel. but this, is a political decision..
    Sep 2013
    Thanks po mas naliwanagan na ako. Pero diesel engines last longer than gas engines daw po?
    Aug 2014
    I think its how you do PM on the engine itself, may it be diesel or gasoline... though makapal talaga ang diesel engine in terms of build than gasoline engine.. kasi yung pag sunog ng diesel sa loob ng engine is thru compression, while gasoline, is thru spark.. kaya mapansin mo gasoline engine, maliit compared to diesel.
    Reliability
    Both are reliable depending on the maintenance, but diesel should last longer because the block is designed to handle higher pressures.
    Maintenance
    Diesel motors are generally costlier to maintain if you follow 5k OCI because lube alone cost more than lube used for gas. Extending OCI and PMS to 10k kms could make maintenance cost equal to gus, but then diesel parts are costlier if they break. Newer diesel motors needs more attention/care because of bad fuel & running condition at tropical climate. Gasoline are generally more cleaner, hence doesnt need much attention aside from regular PMS.
    Cost
    Newer Diesel motor(those commonrail + turbocharged) cost more because of the technology used. Old rotary injection non-commonrail pumps are sturdier and cheap but doesn't meet newer emmission standards.. Gasoline are cleaner, doesnt have complicated emmission control and usually not turbocharged, so they cost less than diesels.
    Etc po
    Diesels are more complicated packed with newer technology thats why they cost more. Most diesel applications are for commercial use, hence the advantage of higher resale value.
    Running cost - diesel has more torque more energy content so it uses less fuel to move a mass.. You save more fuel using diesel and our gov't subsidizes the cost so diesels here are cheaper to run than gaz.
    No much small cars diesel here because manufacturers are playing safe.They know in the long run, bad Ph fuel quality will kill the motor. Ph fuel is dirty and still uses 500ppm sulfur. Most newer Diesels uses high pressure injectors, injectors esp those piezo electrics wear faster when exposed to dirt/water contaminants and they cost hundreds of thousand to replace. High sulfur kills the cat plus will plug most DPF, re-burn cycles will then be needed more often translating to waste of fuel.
    Availalbility of course will depend on demand/ how much consumers are willing to spend. Most middle class families would rather buy a sub-million econo car that could move 5 people and don't have to worry much about maintenance.. Gasoline cars falls in that category while most diesels have to be strippen down as much amenities just to bring down at the price of consumer level and yet still it cost more. So price point, mahal talaga ang diesel cars most families would rather get the cheaper gasoline di bale na mahal ang fuel. But some that could afford the initial cost of ownership and knows the maintenance part would chose diesel, bawi na lang sa fuel cost. hehe
    Sep 2013
    ganun po pala fan pa naman ako ng diesel.maraming salamat dir!
    Diesel engines will last longer than gasoline engines because of the heavier components. It also has more powerful torque than gasoline engines making it more fuel efficient and fit for daily heavy traffic place such as metro manila.
    Ive been driving my mitsubishi L200 for the past 18 years with no engine trouble at all. It is currently logged at 390,000kms and the engine was never overhauled or taken apart. Key to long lasting engine is regular change oil. The only time it did stall was when the clutch was so worn out it wont move but the engine is still running.
    IMO, get a diesel engine powered vehicle.
    Oct 2009
    Quote Originally Posted by usokpower View Post
    4D56 din ba yung engine ng L200? Sulit na sulit ka na dyan sa L200 mo sir ah.
    Reliability - depende na sa PMS. Pero diesel engines requires more attention.
    Maintenance - Diesel engines cost more on PMS's. Diesel engine requires more oil than gasoline engine.
    Cost - diesel engines are more expensive than gasoline engine
    For me, diesel engine are more fun to drive because of its better FC.
    Jan 2017
    "I also have the same idea. akala ko makakatipid ako pag diesel."
    Jun 2012
    Bro dapat ata same model? Accent gas and diesel. O kaya innova gas and diesel. Kasi talagang mas mura ang mirage kaysa sa accent gas
    Quote Originally Posted by dct View Post
    but why do you want to limit yourself to "same model" combinations?
    Jun 2012
    Para apples to apples ang comparison
    Pag same model mahahabol naman talaga within 5 years as long as mataas mileage. But yun nga, pag gas mas marami options. And mas maganda for me Mirage GLS kaysa gas Accent.
    Jun 2006
    I own a gas innova and sometimes drive a diesel innova. Mas pagod ako sa byahe sa diesel mainly due to the vibration and noise of the diesel engine. Both innovas almost the same in age and mileage.
    Jun 2006
    Diesel pulls more than the gas, but when raced, almost the same lang ang acceleration. Diesel power starts to strain only from 130kph up to the max of 160kph while gas goes straight to 180kph. The power of the vvti is mostly availanle from 3000rpm up. While the diesel will pull strongly at idle.
    Jul 2006
    IMHO.
    Pareho lang for both. In terms of maintenance, efficiency, ek-ek-chuva.
    I'm pretty sure some of you guys here would balk at my conclusions.
    I have both diesel and petrol cars, old and young timers alike.
    Vios E AT mas mahal ng 100k and less efficient so definitely the Accent CRDi will be cheaper in 5 years if the mileage is high. If 10k km lang per year I think the Vios will still be cheaper, katamad icompute hehe.
    With the Accent diesel though dapat hindi masira turbo or else ang laking talo na nun kagad. With a Vios or any basic gas engine car, wala namang bumibigay na ganun kamahal within 5 years.
    Ang issue ko sa diesel car ko vs. my gas one, aside from the cost & efficiency of the diesel is that sa diesel, di pwede yung pag para, patay agad. Ipapa-cool down pa yung turbo, di gaya ng gas na pwede patay agad. Pag nag mamadali, kailangan pa antayin. Di rin advised na extended idling (as per manual). Medjo mas maalaga talaga diesel.
    Jun 2006
    Yan din isang issue ko sa diesel ngayon, extended idling. Madalas ako maghintay ke esmi or sa school ng mga bata, minsan morethan 1 hour pa. Definitely maluluto kagad turbo pag ganon.
Diesel engine cars vs gas engine cars. Newbie po
