Results 11 to 15 of 15
- Jan 2008
- 6
January 31st, 2008 01:58 PM #11Hi C190,
How much do u think it will cost me to repair my smoke belching engine sa Diesel KIKI?Di ko pa napa-calibrate yung strada ko since I bought it in yr. 2000.
January 31st, 2008 04:49 PM #12
if i remember it right around 5k for my strada 6 yrs ago...
depende sa parts to be replace ang costs..
pero very professional ang service compare to others i tried
before meron akong dinala sa kanila for estimate-after some check up-they refuse to calibrate di daw kelangan...
kung sa iba yun malamang baklas na injection pump ko
shop is near Ford Edsa (Fema Rd.)
Bosch Calibration yata yung signage
8-5pm mon-sat
- Jan 2008
- 6
- Sep 2006
- 1,335
February 2nd, 2008 12:50 AM #14hello dieseldude,
well ung prob kasi ng 123 ko is may noise coming from the engine na wasnt really there before. sabi ng friend ko na may 123 din it may be fuel knock kasi kaka overhaul lang kasi nung march ng 123 ko and sabi nya it may need calibration na para mawala ung noise. what do u think dieseldude? thanks..will be waiting for ur reply.
First thing to do is the check injection pump to engine timing, most especially of knock comes from all cylinders.
Faulty nozzle/s can also cause fuel knock. Loosen one high pressure line at a time. If Knock stops on a specific cylinder, then you may have a possible faulty injector. Interchange injectors between a good cylinder and a knocking cyinder. If knock transfers, problem is on that specific injector.
Sometimes, fuel knock comes from unequal comrpession pressures between cylinders on newly ovehauled engines. But since your engine is now almost 1 year since overhaul, we can assume that cylinder compression is normal if overhaul and break-in were properly done.
Knock can also be due to unequal timing and fuel output from each pumping element of the injection pump.
Try the first two tests first: timing and injector analysis before proceeding to the more expensive tests.
I suggest that we transfer to our Diesel Fuel Injection Helpdesk at the worshop forum.
- Sep 2014
- 1
September 8th, 2014 02:34 PM #15just had the engine of our Pregio van changed due to a crack on the block of the old engine. Kaya lang with the new engine, may mga vibrations. I was told to have it calibrated. Any thoughts on this and how much ang kakailanganin?
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
