Results 1 to 15 of 15
    Aug 2005
    anyone know a good shop to get my w123 mb diesel calibrated? im from the qc area so mas maganda if malapit lang..
    tanung mo yung Rudy's Diesel Calibration sa may bandang Frisco
    or Speed Ultimate sa Balintawak
    Bosch therefore kay sir Jake at Diesel Central. Its right beside Capitol Medical Center at Quezon Avenue.
    Quote Originally Posted by 4JGtootsie View Post
    pare,
    merry christmas, tanong ko lang kung mag kano aabutin ng total calibration sa 4d56? maraming salamat.
    Archie, Merry Christmas Bro!
    It will depend kung injector cleaning, delivery valve replacement lang. kung tatanggalin ang pump at isasalang sa test stand mas tataas ang cost ng labor at possible parts to be replaced inside the pump (worst case scenario).
    Dieseldude is the real expert but he is still on vacation. I am sure sasagutin niya inquiry mo once he gets a chance. Or you can visit his help desk at the workshop sticky section.
    Mar 2003
    central diesel on q. ave is highly recommended. mr. jake arellano really knows his stuff.
    Sep 2006
    Quote Originally Posted by jvm13 View Post
    Benz 123 uses a Bosch diesel fuel injection system.
    Central Diesel is a Bosch Diesel Center. We do this type of work.
    What seems to be the problem? Calibration may not be required.
    See other posts at the Tsikot Workshop Forum under Diesel Fuel Injection Help Desk.
    Bye,
    Dieseldude
    Aug 2005
    Quote Originally Posted by Dieseldude View Post
    Bye,
    Dieseldude
    hello dieseldude,
    well ung prob kasi ng 123 ko is may noise coming from the engine na wasnt really there before. sabi ng friend ko na may 123 din it may be fuel knock kasi kaka overhaul lang kasi nung march ng 123 ko and sabi nya it may need calibration na para mawala ung noise. what do u think dieseldude? thanks..will be waiting for ur reply..
    Sep 2006
    hello dieseldude,
    First thing to do is the check injection pump to engine timing, most especially of knock comes from all cylinders.
    Faulty nozzle/s can also cause fuel knock. Loosen one high pressure line at a time. If Knock stops on a specific cylinder, then you may have a possible faulty injector. Interchange injectors between a good cylinder and a knocking cyinder. If knock transfers, problem is on that specific injector.
    Sometimes, fuel knock comes from unequal comrpession pressures between cylinders on newly ovehauled engines. But since your engine is now almost 1 year since overhaul, we can assume that cylinder compression is normal if overhaul and break-in were properly done.
    Knock can also be due to unequal timing and fuel output from each pumping element of the injection pump.
    Try the first two tests first: timing and injector analysis before proceeding to the more expensive tests.
    I suggest that we transfer to our Diesel Fuel Injection Helpdesk at the worshop forum.
    Nov 2006
    DIESEL KIKI 920-6606/9206639
    Along EDSA
    80's pa calibration shop na to
    Pwede mo pa check kung kelangan na talaga calibration,they dont calibrate if not necessary and check up is free...
    My former pajero,strada and xtrm were calibrated there
    Jan 2008
    Hi C190,
    How much do u think it will cost me to repair my smoke belching engine sa Diesel KIKI? Di ko pa napa-calibrate yung strada ko since I bought it in yr. 2000.
    Nov 2006
    Quote Originally Posted by optimusprime7 View Post
    Hi C190,
    if i remember it right around 5k for my strada 6 yrs ago...
    depende sa parts to be replace ang costs..
    pero very professional ang service compare to others i tried
    before meron akong dinala sa kanila for estimate-after some check up-they refuse to calibrate di daw kelangan...
    kung sa iba yun malamang baklas na injection pump ko
    shop is near Ford Edsa (Fema Rd.)
    Bosch Calibration yata yung signage
    8-5pm mon-sat
    Jan 2008
    I see, thanks C190. Itry ko pa-repair don.
    Sep 2014
    just had the engine of our Pregio van changed due to a crack on the block of the old engine. Kaya lang with the new engine, may mga vibrations. I was told to have it calibrated. Any thoughts on this and how much ang kakailanganin?
Diesel Engine Calibration
