Our newly repaired 4jx1 had a new problem kanina.
Diesel is dripping out of the tailpipe.
What's the culprit?
Mean A/F mixture?
Ano gagawin? reprogram the ECU?
Unichip upgrade?
The Cylinder Head, CH gasket and 4 injectors are newly replaced.
TIA.
What's the culprit?
Mean A/F mixture?
Unichip upgrade?
TIA.
with black or white smoke? any diagnostic trouble codes? bring it back sa gumawa for further diagnosis, 4jx1 is a very problematic engine esp the injectors kaya balik agad sa gumawa asap. check the oil level kung tumataas indication ng leak ng injectors o-rings.
It might still be the O-rings... if the job is still under warranty, you should have it checked again.
pwede rin yan sq. pero mas maganda is pa check mo na sa casa kung maganda andar. it might need a tech 2.
