I had the idle control assembly replaced last Saturday. Now, the check engine light is gone. Idle is stable but seems to settle at around 1000 rpm. It should be around 650-850 rpm with this model. I tried to adjust the idle screw to 800 but it always seem to settle at 1000 rpm after a while. Also, the engine seems to be a little sluggish than usual, like a bad timing. Should the timing be adjusted when servo is replaced?
