Any thoughts?
Gamit ka na lang ng Caltex fuel, may kasama yung maliliit na tao na naglilinis ng engine mo.
Avoidance
Keep air filter clean
Change oil at recommended intervals
Use correct fuel
Use the recommended engine oil
Refrain from using fuel additives
Keep the PCV clean and working
Keep the engine temperature at recommended temperatures by not tampering the thermostat and radiator cooling fans
Avoid short start/shut down cycles
Avoid prolonged engine idling
pag nag carbonized ka, it may even create problems. nakakatulong ang carbon na lapat na lapat ang valves ng sasakyan. pag natanggal carbon, may singaw. leave it as it is unless i grind mo ulit ang valves mo. just my thoughts.
