Results 1 to 8 of 8
    Sep 2014
    Any thoughts?
    Feb 2009
    Old trick. One of a couple different procedures
    Italian tuneup hehe....
    Mar 2012
    Gamit ka na lang ng Caltex fuel, may kasama yung maliliit na tao na naglilinis ng engine mo.
    Feb 2009
    Quote Originally Posted by maki mi View Post
    Maitim na maliit na tao ba?[emoji3]
    Jan 2008
    what can you suggest?
    Can this work on modern efi engine? How about on diesel?
    Feb 2009
    Avoidance
    Keep air filter clean
    Change oil at recommended intervals
    Use correct fuel
    Use the recommended engine oil
    Refrain from using fuel additives
    Keep the PCV clean and working
    Keep the engine temperature at recommended temperatures by not tampering the thermostat and radiator cooling fans
    Avoid short start/shut down cycles
    Avoid prolonged engine idling
    Jan 2011
    pag nag carbonized ka, it may even create problems. nakakatulong ang carbon na lapat na lapat ang valves ng sasakyan. pag natanggal carbon, may singaw. leave it as it is unless i grind mo ulit ang valves mo. just my thoughts.
Decorbonizing an engine
