Results 1 to 10 of 24
- Dec 2007
- 28
July 1st, 2008 06:43 AM #1I suspect that my car has a damaged piston ring because it continues to consume a lot of oil even though I had the valve seals replaced already.
My car was overhauled about a year ago. Do I need to have it overhauled again? Is there any cheap way of replacing the piston ring without overhauling the engine?
What happens to the engine if I continue to use my car with a damaged piston ring? Wala pa kasing budget sa ngayon e.
Do you know of any shop you can recommend who can do the above repair at a reasonable/cheap price in Makati/Pasay area? How much would I need to budget for the repair?
July 1st, 2008 07:40 AM #2
Continue to use your car and you'll consume more oil. Pede naman "dukot" yan. Dukot ng piston ring not the other "dukot" in your mind guys.
July 1st, 2008 09:18 AM #3
yup sir ganun na lang gawin nyo mag dala na lang kayo ng extra oil sa car nyo
gaano ba kabilis mag bawas ng oil??
BANNED BANNED BANNED
- Jul 2003
- 2,267
July 1st, 2008 09:42 AM #4dapat nung una mo siya pinagawa, piston ring na agad ang pinasilip mo. yung valve seals kasi bihira yan mag-cause ng oil consumption.
July 1st, 2008 04:50 PM #5
before you conclude na piston ring ang sira please check:
1. maiitim ba usok sa tambutso?
2. kung maitim ang usok, remove the the spark plugs kung maitim din (maraming carbon)
3. dapat isa lang ang maitim kung piston ring ang sira. very unusual na lahat ng piston ring masira ng sabay-sabay
4. kung lahat maitim most probably na di piston ring ang sira, maaring leak lang somewhere.
- Dec 2007
- 28
July 2nd, 2008 01:53 AM #6
Thank you po sa reply.
Pano po ba yung dukot? Aside from the piston ring ano po ba ang kailangang palitan pag pinadukot ko yung piston ring? Magkano po sa tingin nyo ang labor cost ng dukot compared sa overhaul? Specialist po ba ang kailangan o halos lahat ng mekaniko marunong magdukot ng piston ring?
July 2nd, 2008 02:02 AM #7
madaming pwedeng reasons why makonsumo ng langis ang kotse... pwedeng may leak... pwedeng may matigas na gaskets, pwede din sa bandang transmission may problem din, pwede dingbaluktot na mga barbula... etc...
general overhaul ba ang ginawa last year? whether it's a general or a top overhaul you should track ung mga pinalitang piyesa. try to first check if walang tagas by having a decent engine wash (those who really know how to do it without damaging your electrical components- alternator, distributor, and everything else electrical- ung mga male and female receptacles pwede ding mapasukan ng tubig and masira), and see if may tagas.
if wala, it can be the transmission or the engine parts already.
HTH
- Dec 2007
- 28
July 2nd, 2008 02:11 AM #8
- Dec 2007
- 28
July 2nd, 2008 02:15 AM #9
- Dec 2007
- 28
July 2nd, 2008 02:20 AM #10
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
