As what I have read before , CMIIW , CRDI engines is sensitive to water or air in the fuel , kaya nga me water filter at sensor sa fuel linedi ba? For air di ba dapat Hindi puede matuyuan as in running the engine empty at masisira engine tama po ba?
Q ko Lang ;
How to replace the fuel filter ,kasi initially di ba bago pa yun filter after replacing it so me air talaga na papasok muna sa engine before umakyat yung diesel sa injectors.
Kasi before on my gas fed car kasi pag nag plait ako fuel filter , antagl bago pumas ok yun gasoline sa EFI ko ,kailangan pa I pump ko pedal then tsaka sya aandar.
