Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Apr 2014
    Ang rated na engine oil for my Corolla GLi 1.6 4afe according sa internet search ay 10w30 .. Akala ko sa america or cold countries lng pwede ang xw30 kasi mostly forums na seach ko ay US at canada, pero may na basa din ako isang forum sa pakistan na 10w30 rin ang rated oil sa 4afe engine nya ..
    Considering na mainit dito sa pinas lalo na pag summer, ok ba gamitin ang 10w30 na mineral oil ?? Walang problema sa 10w30 na fully synthetic kasi synthetics are made to sustain excessive engine heat ...
    Currently using Mobil 15w40 mineral oil, plano ko try ang 10w30 either mineral or synthetic sa susunod na PMS ... Marami din akong nabasa na hindi na bagay ang synthetic sa old engine kasi baka mag leak .. Pero kahit 20yrs old na yung Corolla ko, 87k plus kilometres lng natakbo kasi yung dating may-ari ay chinese business man na mahilig sa kotse, pero di nya gaanong ginagamit kasi marami syang sasakyan .. sa city driving minsan ginagamit nya pero kung out of town yung pick up or SUV nya ginagamit nya ...
    ano sa tingin nyo ?? Pwede ko bang ity ang 10w30 synthetic ?? kung 10w30 mineral naman, kaya ba nang manipis na mineral oil ang init ng makina at init ng panahon dito sa pinas considering na mas mainit sa pakistan kasya pinas at 10w30 rin ang rating ng 4afe engine sa pakistan ???
    Quote Originally Posted by Dezaremos View Post
    it snows in some areas of pakistan, po.
    i would use the oil recommended by toyota for its car. give the casa a call if you do not know. why guess, when the answer is just a call away?
    Another thread? Heheheh
    If you are previously using 10w40 or 15w40, stick with that.
    Mineral or synthetic depends on your filter...
    most oem filters for the old engines were only good for 5000km hence stick with mineral oil.
    K.I.S.S.
    Mar 2004
    Honda uses 10W-30 mineral oil. There's new study recommending 10W-30 motor oil over 15W-40.
    Apr 2014
    so you're saying I should only use 10w30 mineral instead of 10w30 synthetic due to my old engine ???
    Can you post a link on that new study you're referring that 10w30 is recommended than 15w40 ...
    Its for newer engines... the study was conducted on diesel engines.
    What is PC-11? By Shell ROTELLA
    For newer petrol engines theyre studying 0w16 and 0w8 viscosities. Some cars are already using 0w16 in japan.
    Honda has long been using their 0w20 VTEC green synthetic oil for their newer cars. It offers better fuel efficiency compared to the older 5w40 VTEC LEV synthetic oil.
    Theyve been using that for almost a decade in the USA because of CAFE standards.
    Mar 2004
    10W30 are mostly mineral oil, 5W30 or 0W30 would be synthetic.
    Madami din 10w30 na synthetic. Usually basta 10w30 synthetic na. Iba yung fully synthetic ha. Baka yun sinasabi mo.
    Feb 2009
    the viscosity rating is rated by the society of automotive engineers and is only based on the oil's ability or resistance to flow and the ability to provide surface tension to stay between the moving parts. also point to consider is the API rating.
    http://www.aa1car.com/library/api_mo...ifications.htm
    Mga kotse at SUV stick to 5w30 or 10w30 na lang. Kahit adventure at crossswind maganda takbo sa 5w30.
    15w40 jurassic na yan pang mga trucktora na lang yan.
    so why does it seem that there is a tendency to lighter oils on today's modern engines?
    Oct 2015
    My guess is tighter tolerances between engine parts and to get better fuel economy.
    Jul 2015
    Im sticking to motul 10w40, i was at motor image for a free oil change a couple of months back, i asked the service manager what viscosity do they use for the brz, wrx, sti and the forester? he said 5w30 for the non turbo models and 10w40 for the turbo ones, told him that it says on the my oil cap 5w30, his explanation was, the manual and oil cap came directly from japan, they have a much cooler climate, yun daw utos ng head office, i thought he was just giving me a lame excuse, so what i did was changed my HUD to show the engine temp, it was 89c-95c on idle to normal everyday driving, it did went up to 110c when i was doing 230kph on the tplex, it was cold around xmas time, imagine if it was summer, my tractor might overheat.
    Quote Originally Posted by Wh1stl3r2 View Post
    the oil passageways are so small, thicker oils would have difficulty getting thru them?
    Depende sa kotse yan at paano mo gagamitin. Meron mga car na kahit ano rainy season or summer dapat stick sa 5w30 or 10w30 like the tamaraw fx and trooper. Meron ako nakausap lagi daw nasisira turbo nung fx nakatatlo palit na at 15w40 naman daw gamit nya "tamang tama" daw sa temperature sa pinas. Pero nakalagay doon sa oil cap use 5w30 oil. Sabi ko sundin mo malay mo hindi na masira turbo. Ok na daw at nalessen yung usok.
    Even the adventure crosswind using 10w30 at 5w30 oil mas maganda performance.
    Pero kung ihahataw mo talaga eh gumamit ka 10w40 or 15w40. Pero manila driving at normal highway driving masyado malapot.
    Apr 2010
    so, kung sa manila lang mostly gagamitin ang sasakyan, mineral oil lang ang kailangang gamitin or lagyan sa makina?
    AFAIK, kapag fully synthetic oil ang gagamitin, mga 10k KM ang itatagal nito.
    Feb 2009
    compare your engine oil with the water in your bath tub. you don't want to soak in it over and over. you will want to change the water as soon as you can
    Apr 2012
    10w30 oils can survive the heat in Manila naman.
    Our Commuter uses 15w40 ngayon due to budget limitations. Pero nung 10w30 gamit ko mas tahimik takbo ng engine
    Sent from my LG-H818 using Tapatalk
10w30 or 10w40 ??? Mineral or Synthetic ....
