Results 1 to 10 of 11
BANNED BANNED BANNED
- Aug 2007
- 999
June 1st, 2008 03:55 AM #1galing ako sa casa nagpachange oil.....nung inangat sa lifter yung car eh basa daw yung crankshaft ko.....
as soon as possible ko ba kailangan ipagawa ito or pwede hidni muna kung hindi naman tumutulo?
mababasa ba yung timing belt pag may tagas yung crankshaft?
June 1st, 2008 04:05 AM #2
sa tingin ko hindi naman ganun kalala yon lalo na wala pang tulo, pero dapat ay iplano mo na din ipagawa, kasi minsan simple lang at sealant lang ang katapat nyan sa bandan valve cover...or find out the source kung anu ang may dahilan...at saan ang leak.
June 1st, 2008 04:54 AM #3
- Feb 2007
- 134
June 2nd, 2008 09:29 AM #4Have it assessed as soon as possible... kasi crankshaft replacement is expensive... more than 10k... not to mention the labor... general overhaul yan...
although nung nagkaproblema ako sa crankshaft a week ago they were telling me na baka makuha sa dukot... pero I doubt it... kasi mahabang part yun kaya kelangan talaga buksan...
- Nov 2006
- 299
June 2nd, 2008 12:36 PM #5if that is just a seep, then its just normal but if its formed into drip then it needs to be fixed.
- Jan 2008
- 4,726
June 2nd, 2008 06:36 PM #6make sure where it is coming from... possible sa crank case lang yan and worst galing sa OIL SEALS... check kung malakas ang tagas especially kung may tumutulo na sa floor when you park the car..kung slight seepage lang ok lang yan..hindi nyan mababasa yung timing belt mo... the best way is isabay mo yan sa timing belt change...
my kia carnival also had that oil seepage sa crankshaft then isinabay ko nalang sa palit ng timing belt yung mga oil seals...kahit may tagas na yung oil seals ko hindi naman nabasa ng oil yung timing belt
- Aug 2007
- 999
June 2nd, 2008 11:18 PM #7*yapoy86
yung crankcase eh oil pan din ba tawag doon? Kasi sa oil pan ko may tagas talaga pero konti lang.....
KAsi nung inangat sa lifter eh parang basa yung area malapit sa timing belt.... pero walang tulo....
June 3rd, 2008 01:26 AM #8
- Aug 2007
- 999
June 3rd, 2008 01:48 AM #9*v6dreamer
so iba ang oil pan sa crankcase or the same?
kasi sabi sa akin bili daw ako oil pan gasket/crankcase gasket
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 3rd, 2008 08:37 AM #10it might also be the oil pump o-ring. if you're pulling down the oilpan and replacing the crank seal then it's the perfect time to replace it as well.
Nakita ko nga din sa brochure na meron, kaso sabi nung service advisor, kapag J DAW auto down lang...
