Results 21 to 22 of 22
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 18th, 2008 05:00 AM #21on overhead cam engines the oil will really jump up when you remove the oil cap. syempre kasi may parts na gumagalaw.
now before comming to the overhaul conclusion there are many different factors to consider... compression, smoke, oil/water consumption, etc.
if because of the jumping oil alone you come to the conclusion na kelangan i-overhaul then the mechanic is not that good.
- Jul 2008
- 9
July 17th, 2008 11:54 PM #22there are lots of factors to consider kung talsik lang ng oil ang pag uusapan, puedeng malakas lang ang oil pump or talsik galing sa racker arm pag overheadcam, try to check your breather kung may oil at usok na lumamabas, pag meron candidate na engine mo sa blow-by, pag nag overhaul ka ulit change mo na lang mga bearings nia , main, conrod bearings sa crank saft kasi nag memetal fatigue din yun mga yun eh.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
