Results 1 to 12 of 12
    Dec 2017
    Hi Tsikoters!
    I have a 2012 Hyundai Accent (gas) whose engine hesitates or judders every time I engage something electrical like the power windows, aircon, headlights, wipers or sometimes even just the radio.
    The juddering is quite subtle; there is very little vibration in the cabin. Just enough to be felt through the steering wheel and annoy me.
    I have tried replacing the battery. It was still from the factory anyway. But that did not get rid of the juddering.
    I think I want to try fuel system cleaners next (sea foam treatment spray via air intake). But if anyone has any suggestions, it would be highly appeciated!
    Quote Originally Posted by jeffimperial View Post
    Hi Tsikoters!
    my wild guess is,
    your problem is electrical-related, and not engine-related.
    it appears that the current going to your engine is diminished when an electrical appliance is opened.
    this suggests to me, of a poor electrical contact, that limits the flow of electricity. it is un-able to conduct larger amounts of electricity.
    good luck.
    Jul 2013
    Is the rpm affected when you turn on electricals?
    I'm guessing its the engine load of the alternator, medyo ramdam lang ngayon due to the age of the car and (after 5 years) luma na din engine supports mo
    yup, poor electrical contact. maybe a loose connection somewhere between battery and main fuse/relay box. or a main fuse about to go, already partially melted. try tightening all the electricals and check the main fuses. are there any signs of burnt insulation?
    Mar 2004
    Have alternator checked also ... if it is still giving proper current and charging the battery at full capacity ... or maybe your engine needs de-carbonizing ...
    Oct 2009
    kung sobrang hina lang naman natural lang yan syempre may load ung mga electrical mo kaya medyo bumababa ung kuryente
    Dec 2017
    I've checked the fuse box, at walang sunog or natunaw don. Just last week, ibinaba yung dashboard ko for major cleaning ng air con. We weren't looking at the wiring too closely pero I would think na obvious yung nasunog na wiring/insulation so nakita sana siguro namin kung meron.
    Dec 2017
    Like others suggested, thanks I'll get the alternator checked. Pero as far as decarbonizing goes, hinihintay ko na lang dumating yung order kong seafoam treatment; I'll update here kung may ramdam na improvement.
    Feb 2009
    Have you done the routine maintenance procedure first?
    The vehicle is almost 6 years old. If the idle air control valve and the air passages haven't been cleaned yet, do this first. Don't speculate that the ELD ( electrical load detection) circuit is bad. Over time, the crankcase emissions, particulates and buildup of gum and varnish makes this idle air control valve sluggish or stuck
    Mar 2004
    Dismantle and clean EGR and also clean MAF sensor ...
    Apr 2009
    agree with this. also, check that grounding wires are properly "grounded" or tightened to the body, chassis, engine & tranny. a good grounding kit can can also fix electrical gremlins that comes with age...
    Feb 2009
    EGRs only operate when the throttle is around 40% and above and when the coolant temperature around 180°F or higher. These two are the enable criteria for EGR operation. It does not operate all the time.
    Have your PCM scanned. Some PCMs and some scan tools are capable of displaying changes in electrical load.
Engine judders when electricals are engaged
