Results 1 to 6 of 6
    Mar 2004
    Guys, I would like to ask your help. Can you recommend to me what kind/ brand of oil, oil filter and spark plug should I use for my 97 Civic Vti A/T.
    I normally bring it to car shops for change oil and other maintenance and I noticed that the prices of these products are a bit jacked up. I am planning for my next oil change to just buy these items from car stores ang just pay for the labor of the mechanic. I think it is a bit cheaper.
    Oil may not necessarily be fully synthetic. If you can provide the prices so much the better. Also i would appreciate if you can recommend stores or malls where these items are cheaper from other sources. thanks a lot for the usual help.
    ride safe guys
    Jan 2003
    engine oil: try motul h100. its around 380/liter
    oil filter: OEM
    sparkplugs:OEM NGK or Denso Iridium
    Engine oil: Kung tamang budget lang:
    Mineral oil (all 20w-50):
    -Shell Helix Super (yellow bottle, P620-P650/gallon)
    -Caltex Havoline Formula (red cap, P580-P620/gallon)
    -Mobil1 Super XHP (P650-680/gallon) <= rare, kung may mahahanapan ka!
    -Castrol GTX (P620-P650/gallon)
    -Total Quartz 5000 SM (P600-P630/gallon)
    Semi-syn:
    -Helix Plus (10w-40, P1k+/gallon)
    -Castrol Magnatec (10w-40, P960-P1k+/gallon) <= naglabasan na po sa mga auto supply 'to
    -Total Quartz 7000 (15w-50, P960-P1k+/gallon) <= I'm using this one!
    -Mobil Super S (15w-40, P1.2k?+/gallon) <= rare, hirap maghanap nga lang, just giving you reference!
    Fully-Syn??? Kahit di na siguro kung tight budget ka lang naman, OKS na kahit semi-syn!
    Oil filter: BEST if OEM parin, medyo pricey nga lang! You could also try the well-known 'VIC' Oil Filters (P140+?) (Warning: Make sure you find the authentic one...dameng fakes naglabasan nito!)
    Sparkplugs: stock NGK (P90-P100/plug), or Bosch Platinum (P130-P140/plug)
    NOTE: *All you can purchase/canvass at your suking auto supply, gas stations or malls near you! :D
    *Above price mentioned are updated. Yes nagmahalan na po lahat!
    Nov 2003
    for filters we use vic. plugs we use NGK.
    oil we use motul
    San ba mall avail ang motul products?
    Mar 2004
    thanks a lot for the replies. this will help me a lot.
what oil, filter amd sparkplu would you recommend?
