Results 1 to 13 of 13
    Jan 2008
    Kasi po sa umaga, syempre malamig yung makina, pag-start ko, tataas ng 2k rpm tapos kapag mainit na baba na sya ng 1.5k rpm... Ngayon ang problema taas baba na sya (from 1.5 to 2k rpm)
    Nangyayari lang po ito during cold start. Magnonomorlaize lang sya after a few minutes na umaandar ako. Kapag mainit naman yung makina, wala naman akong problema.
    Help po... Maraming salamat.
    Jul 2006
    Quote Originally Posted by sukiyakimoto View Post
    Magnonomorlaize
    Again again? nabulol ako dun ah
    Sounds normal to me, ganyan yan to quickly warm up the catalytic converter so it can perform its job. Kailangan mainit ang catalytic converter para efficient ang pagtanggal niya ng noxious emissions sa exhaust. It's just warming it up faster, plus it also warms up the engine faster at cold start so you can readily reach normal operating temp. Syempre pag mainit na, no need to do this so hindi siya nangyayari.
    Baka gusto niyo rin banggitin kung anong modelo ng sasakyan, what year, etc so others can help you out sa susunod. Welcome aboard.
    Jan 2008
    ay, heheh... Magnonormalize pla.. hahaha... sori...
    Honda city 2002 (Type Z) ung sasakyan ko.
    Jan 2008
    ay, heheh... Magnonormalize pala.. hahaha... sorry...
    Honda city 2002 (Type Z) yung sasakyan ko.
    sori sa double post. paki delete nalang po ung nauna.
    Dagdag ko lang po. Yung taas baba po nya e mabilis.
    Jan 2008
    cold start RPM at 2,000RPM i think is too HIGH... I have a 323 Mazda DOHC EFI Engine during cold start ang RPM lang eh around 1000 to 1,200 only but when warmed up RPM will go down to normal 800RPM to 900RPM.. masyado pabilis yun 2000 RPM and normal at 1,500RPM?? have your qualified mechanic check and diagnose your RPM readings
    agree 2000 RPM at cold start is too high. there's definitely something wrong.
    try to have your ISCV yata tawag dun (idle switch control something) checked. Have the throttle body cleaned including the intake manifold.
    Jan 2008
    Sir, ok na po yung problem ko. May inadjust lang po sa may bandang throttle body. Hindi po idle switch yung inadjust, ewan ko lang po kung anu yun. Nakalimutan kong itanong e. heheh.
    Maraming salamat po sa mga nagreply. Paclose na lang po ng thread na ito.
    Nov 2003
    they probably adjusted the idle screw lang.
    Quote Originally Posted by speedyfix View Post
    Yung auto ko, inadjust ko yung idle screw kasi namamatay yung makina, kaso may cycle pa rin na 1,500 to around 500, tapos me chances na namamatay yung makina?
    Nov 2003
    have the throttle and idle up cleaned. it may help.
    Apr 2004
    I have a problem during cold start also, my car is a GLi corolla 4afe (efi). I'm having a hard time stablizing during cold start, My rpm does'nt go up automaticaly... i resort to stepping on the gas pedal till the engine warms up. What could be the problem??
    Nov 2003
    do the same thing as was stated above siguro.
    Aug 2015
    Sir yapoy. Inquire lang ako. Sensia na ibang topic. I saw your post regarding cat con. Yung sasakyan ko kasi sira na yung cat. Ang mahal ng bnew at ang hirap maghanap ng surplus. Ano bang magandang gawin.salamat
coldstart problem... help...
