Results 1 to 10 of 10
    Apr 2011
    Guys, help.
    Yung engine kakaiba yung vibration nya when running at high speed or around 4th and 5th gear.
    its kinda violent na I can feel it shaking my ride compared to normal engine vibration.\
    then ang pag nag shake na sya, bibitawan ko lang yung gas and go to neutral, magiging normal na ulit
    wala naman weird noise. ok din ang engine rhythm pag low speeds; 1st 2nd 3rd gear.
    my engine is 4d56, mitsu adventure 1st generation
    any idea anong problem? THANKS!
    Jul 2015
    What fuel are you using? Thx
    a friend once had this problem... i'll ask him what he found.
    but it definitely wasn't fuel.. it was engine..
    Almost same problem, pero automatic yung akin. When in D and stop, nagba-vibrate yung engine, although pag umandar na eh nawawala ang vibration, nawawala rin when shifted to N or P. Had it checked out, inayos yata yung engine mount, then cleaned the servo, cleaned and adjusted the spark plugs (inusog yung bato). Bawat ginawa nya eh nag test. Nakikita ko naman na unti unti nawawala vibration sa mga test nya.
    Apr 2011
    Please do Dr. D. I'll have my engine check this week. sana hindi serious problem. and btw diesel po.
    Id check engine and tranny mounts, they wear over time. May visible leaks ba o crack/stress marks sa rubber?
    Apr 2011
    Thank you for the input 12vdc. There are no leaks. I haven't checked it thoroughly.
    Dec 2007
    Have your engine support checked.
    Feb 2009
    Confirm
    Is it just the engine shaking or
    The whole vehicle shakes
    Apr 2011
    Sorry for late reply. Thank you for all the inputs. It was indeed tranny mounts. atleast pumunta ako sa autoshop knowing the issue. now its fixed, naninibago ako sa vibration feel ng auto ko.
Engine shakes violently
