Tinanggal ko po yung cylinder head cover nung lancer ko to clean it, and I noticed that the overhead cam, springs and the whole area was full of sticky oil deposits, grime and burned oil flakes, due to bad oil change habit siguro nung previous owner.
I am worried na baka pumasok ito sa loob ng engine and cause problems later on. So I am figuring out how to remove the sludge and flakes.
Pwede po ba na i-scrape ito then flush with diesel so that the dirt will be flushed all the way down to the crankcase, then remove the oil pan to completely drain off the oil together with the accumulated dirt? Wala po bang ibang holes na pwedeng pasukan yung dirt na pwedeng makasama sa engine.
wala po bang pwedeng maging efect yung diesel sa valve seal? TIA
