update ..nakausap ko na po yung agent ng auto ko sa casa ng HONDA..
Servo is good pero......
Kailngan ko daw magpalit ng ECU dahil yung nakakabit sa akin eh ECU na pang VTEC matic.Hindi din daw nila madetect ang problema dahil hindi daw mabasa mabuti ng computer dahil nga hindi daw match ang makina at ang ECU.
Nakakapagod gumastos 12t yung nacanvass ko na worth ng ECU na surplus sa banaue.Parang gusto ko na yata ibenta at magferoza na lang for good![]()
sir try mo kay cinco sa aurora ave malapit sa psba papuntang katipunan, look for manny - 911-11-68 medyo mura kung may stock pwede rin kay baltak masmura dito jun - 7119736. over naman ung 12T
malang more or less 7T may makita ka.
about feroza lakas sa gas nun pre
Parang makulit ang kasa at gusto talagang magbenta ng ECU ah.
I know your sparkplugs are relatively new, pero its worth a try to try and replace them with another set of sparkplugs, kahit used na. That's what they did at Speedyfix last week, at nawala yung pagpitik. As simple as that. And to think that I just installed them last Dec. 30, 2006!
* galactus
sir simula MAYO ng nabili ko po yung auto at hanggang ngayun ay nakakadalawang palit na ko ng brand new sets of spark plugs.Magiging 3rd sets of brandnew SPlugs na po kung papalitan ko pa.Ganun pa man susubukan ko na din.Thanks.
* Joey
sir,hindi ko na po tatawagan,ganun din po naman kailangan ko talaga magpalit ng ECU..kahit wala po sila stock I will try to find some shops that are selling.Thanks bossing you are a big help!![]()
Paalis na po ako.I will post some update and some news later regarding this headache im going through.
Buying ECU for Honda ESi manual `94MdL,Hope it works.
GoodLuck to me!![]()
Gud PM,Just got home w/ my Honda..I bought an Original stock ECU in Banaue and it cost me 10k Php.
Hindi ko na po binalik sa Honda Casa yung auto,maayus at maganda ang takbo ng auto.Sa tingin ko po ECU ang dapat palitan noon pa.
Mamayang konte i-start ko ulit ang auto pag medyo malamig na ang makina..pag nawala po ang erratic idling problem,I think its a good buy.
Yes sir its a good buy for me even its a bit pricey.
Galing din po ako kanina sa Banaue..bumili ako ng bagong Radiator kay Levin.Ok na ok sya,salpak na lang.Now Overheating is not a problem anymore.
good thing sir ok na EG mo and you didnt quit... pareho tayo situation dati still using my ESI..ganda pa rin kac talaga porma kumpara sa ibang civics ^_^
nice to know ayos na auto mo. tagal ko na kita to thread . para ka ciguro nabunutan ng tinik..hehe.. congrats mhen.
share ko lang po. almost pareho ung naging sakit ng ESi 95 ko before. pag preno bagsak RPM then minsan shut off ung engine. palit kmi ng SPlugs. after awhile bamalik ung cra and busted pa ung new SPlugs. check nya coil ng distributor sunog na pala. after replacing the coil ok na po smooth na ride ko.
Thanks..dami ko ng pinalitan dito,halos naka 50k na ko sa mga pagawa at mga pyesa.
Sir Kedrian, ganyan din problem ng ESI ko B4, malikot ang idling. Mahirap hanapin talaga sira. How many times na ko nag pa overhaul. Dami gastos. Last year I decided to change my engine to D16zc SOHC VTEC. It runs good, especially when VTEC engage. Then last 2 months, I encountered a problem. Abnormal din yung idling & my smoke turns black bad.check with the mechanic & diagnosed. Simple lng kagad ang problem Computer box. They have spare boxes. Pag switch sa isang box, ok na kagad. Bunot kagad ang tinik.
Saan po ba may magaling and murang mekaniko for civic esi? pacheck ko lang mga pang-ilalim and brakes.
Yung front signal/turn lights double as park light ba? kasi wala akong park light sa front. thanks.
