Page 1 of 2 12 LastLast
Results 1 to 20 of 40
    This is what happened...
    I bought this car and it there was no problem with it. Suddenly, I felt that the RPM is bouncing from 800 to 100, and the engine almost died. I tried to find a mechanic.. with my RPM falling down to 100. Especially when I stepped on the breaks. Luckily,I was able to reach the HONDA CASA at quezon avenue.
    They told me that their diagnosis regarding this matter was to change the Computer box.Its worth 40T,so I told them "maybe some other time because of lack of budget". So, for the meantime they cleaned the throttle body and issued me a new gasket for it [THROTTLE BODY] and a new air filter.They also changed the sparkplugs.
    So the next day I picked up the car and its fine!So before I left..one of their agents adviced me to change the computer box very soon.What we did is just for the meantime,he said.
    What I did is,I went to Banaue..and look for a Computer Box specialist.Luckily I found one.He told me that the computer box is fine and doesnt need to be replaced.But he told me that the source of the problem (RPM Falling to 100) is the AIR VALVE.So he troubleshooted my engine and had done it successfully.
    Before I left Banaue the Mechanic told me that I also needed to change my cylinder head gasket.Bcuz if not the engine will experience excessive overheating in no time everytime I use the car.
    The next day..I went to see my friend mechanic who lives near our place.I asked him to change the cylinder head gasket together with the timing belt.
    So he adviced me that if ever we will change your cylinder head gasket it is best that we change also the following...
    1.CYLINDER HEAD GASKET
    2.TIMING BELT
    3.TENSIONER
    4.CRANK SHAFT OIL SEAL
    5.CAM SHAFT OIL SEAL
    6.VALVE COVER GASKET
    7.LOWER RAD HOSE [RADIATOR]
    8.SPARK PLUG SEAL
    9.VALVE SEAL
    10. 'O' RING
    =+ ADDITIONAL PARTS +=
    11.CAM HOLDER
    12.PCV VALVE
    13.IDLE PULLEY BEARING
    14.INTAKE MANIFOLD GASKET
    15.WASHER HEAD COVER
    16.WAHSER HEAD COVER [DIFFERENT SIZE]
    17.TUBE A PCV
    *My friend mechanic recommended me to change those stuff because when he opened the engine...all that are listed are tearing and will not last long if I didnt change them.
    FROM CASA: 1.GASKET THROTTLE BODY, 2. AIR FILTER, 3.SPARKPLUGS
    FROM BANAUE:1. AIR VALVE
    So when my mechanic completed and finished the project he asked me to start the engine.
    So heres the problem...
    Everytime I start the engine (especially when cold),the engine is always shaking and its also visible in the RPM gauge.The hand from the RPM gauge is also jiggling from 500 to 1000 RPM. Especially when you're riding it..you really feel the idle moving up and down...feels like the engine is dying even if its not.It doesnt stop even with the aircons ON.I love the car but it annoys me everytime Im using it.
    Help me please,I already spent too much money with this problem and no one can do the trick.
    So far my expenses are already gathered worth 30T more or less.
    HELP me please.
    Help please!
    BUMP!
    Sep 2006
    if i where you.. have it diagnosed sa honda..you'll spend less than 1k for diagnostics then have it repaired somewhere else.. or much better kuha ka rin opinion ng iba see if it matches... ganyan talaga pag 2nd hand walang tigil ang pag palit ng parts due to wear and tear.. i have the same car and model when i bought it last year dami ko ring gastos...
    thanks for the advice master zerg..anyways i will try to bring the car tomorrow or maybe tuesday.
    Any related problem/experiences regarding this matter??Any second options??Advices please.
    Nov 2003
    imo bring it back to your mechanic friend. if he was competent enough to do all the work on the car he should be competent enough to troubleshoot the problems now.
    Kasi Sir,nung pagkatapos na pagkatapos nya magawa yung auto at naikabit na lahat ng parts (refer to my 1st post about parts) ehh... bigla na lang up and down ang idling.Malamig pa nga makina nun e..... eh pag HONDA po kasi pag malamig makina sa 1st start na malamig ang engine..nagpapainit ng magisa ang engine w/ high idling.So ayun rinig na rinig mo ang makina parang naglalaro pati yung RPM meter stick sa dahsboard naglalaro din up and down.
    Kinabukasan po bumalik sya and he did some troubleshooting.What he did was ;nag advance sya ng isang ipin sa timing..tapos pinainit namin yung engine at WHALLA! ok na sya.Pero what im worried about was sometimes in the middle of your mobiling you will feel the idling going up and down..Meaning di pa sya perfect.
    Isa pang nakakainis dyan pag hindi po sya pinainit at ibinyahe mo agad yung sasakyan talagang ramdam mo yung idling UP and DOWN sya. "In short kailangan muna painitin ang engine para medyo tumino ang takbo".Eh hindi naman po normal yun di ba.
    Medyo madami na ko pinalitan at hindi po ako bumibili nang replacement.. Tapos Very disappointing pa yung result ng pagpapaayus ko Y_Y.
    Any shops you can recommend na may experienced sa ganitong problem paki PM na lang po..really need badly.SALAMAT!
    Sep 2006
    best place para sa situtation mo is to have it diagnosed with honda na talaga then have it fixed outside.mas kapa na kasi ng honda lahat yan opinion ko lang po... or try to read the service manual ng ESI.. it really helps kasio nandon ung troubleshooting na rin ng mga different symptoms (download it from HCP)
    Aug 2005
    sir, bka mali ang kbit ng mkaniko sa timing belt wla s timing, tumalon ka lng ng isang ngipin mlking bgay na sa takbo ng engine,pwde rin my ncrang sensor ung mekaniko like tps. map sensor or temp sensor o kaya wla sa tma ung mga vcum hose ng pgblik nya,pwde rin wla s timing btween cam n distributor. check din wring harness ung terminal bka mali or hindi tama ang pagkkbit, check m din ung bckground ng mkaniko bka sya ang mysala lol.. joke! assume k lng na b4 nya gnwa auto mo e maayos ang andar at ovrheatng lng ang prblem.
    pwde m pcheck ky speedyfix nkkta k d2 mraming pstive comments sknya
    Nov 2006
    itry mo daw gawin ito baka sakaling pwede pa,kasi dapat mas nauna ito ginawa bago ang lahat ng repair,pero gaya ng sinabi ko baka sakaling pwede pa.
    idisconnect mo yung positive at negative battery cable at iconnect mo itong dalawang cable,yung cable mismo (positive and negative) at hindi nakaconnect sa battery.kahit hawakan mo lang at idugtong silang dalawa ng 30 seconds at least.at pagkatapos ay iconnect mo na sila sa battery at start mo na ang engine.dont worry it wont hurt anything.
    ang tawag dito ay adaptive relearn.
    mangyari kasi,ang computer ay nagstore ng excessive voltage na hindi makayanan ng capasitor,kaya pamamagitan ng pagkonek ng dalawang cable ay nililinis mo yung voltage memory ng computer at nererelearn mo rin yung adaptive memory nya. wag maniwala sa sinasabi nilang palitan na kaagad ang computer box,na kung tutuusin ay di naman kailangan.
    sana di pa huli ang lahat at matulungan ka nito.
    Nanghihinayang nga ako mga sir's..kasi talagang puro orig pa ang mga pyesa na kinakabit ko dito tska binalik ko sya sa stock..May plano na din ako iparepaint w/ the same color..kinumpleto ko din ang Mud guards,naglagay ako ng center console na pang hatchback tska Cup Holder.Kaso kung ganito naman na erratic idling na walang makapagayus eh anu pang dahilan para pagandahin sya..hindi po ba?
    Ang last resort ko Honda Casa kung walang makakagawa..At pag hindi pa napatino eh ibebenta ko nanaman ito w/c is kabibili ko lang din nung MAYO.
    Ayoko sana ibenta kaso hindi kampante ang loob ko at laging nasa isip ko yung idling na palagi mo nararamdaman ang diperensya.Bago pa nga yung Aux fan motor w/c is 4t ko nabili.Sana nama maayus sya.
    * joey - oo nga bossing nung pinaayus ko to ang problema lang is overheat na ang dapat lang palitan eh cylinder head gasket..dahil hindi na daw nagcirculate ang tubig sa makina para palamigin to at sira na din ang cylinder head gasket kaya tumatagas ang tubig paunti unti sa sira na gasket.
    Pero iniisip ko pa din sir kasi yung mekaniko ko matagal ko na kakilala un..Toyota GLi pa lang auto ko sya na mekaniko ko bale 5yrs ko na syang mekaniko.Magaling at hindi sya mahal maningil.Hindi ko po alam baka nagkamali din sya sa pagkakabit.
    * dennis powell - ginawa ko na sir pero ganun pa din eh..salamat po sa mga ibang nagbibigay ng payo.baka sa july 18 dadalhin ko na to sa Casa.
    kumbaga last resort.pagwala pa din development...benta den mag Feroza na lang siguro ako.
    Sakit sa ulo ng kotse ano? Hehe. Had my fair share of problems with my EG before. Nung napaayos ko na binenta ko na din para hindi ko na sagutin kung magkasira ulit in the future...
    Sep 2006
    i felt the same way with my EG... ok ang honda pag napagawa mo yan para kang nabunutan ng tinik.dont loose hope dude.. like what i've said kung di na kaya ng mechanic pacheck mo sa casa... that doesnt mean na ipapagawa mo na rin don.one way or another if you decide to sell it,kailangan mo pa rin ipaayos yan kac walang bibili or if ever meron babaratin ka...
    * typhoon - yung ibang auto ko dati hindi naman masyado masakit sa ulo.etong eg lang talaga..masyadong malalim ang problema..pagmay pinagawa ka bukas o sa makalawa may bago nanaman..
    Yung toyota corola gli ko naman dati hindi ganito..masyadong basic ang toyota masarap talaga gamitin at kahit saan merong pyesa..sobrang mura pa.
    Nakakasawa lang talaga kasi 5yrs akong naka corola big body.Kumbaga para sa akin po eh maiba naman kaya benenta ko sya(corola).
    Etong eg nakaka migrane kakaisip at kakahugot ng wallet..
    masyadong complikado..lahat electrical source para umandar.
    * MasterZerg - Oo nga sir sana naman matanggalan na ko ng tinik sa lalamunan at ang tanging paraan para mangyari yun eh magawa sya ng perfect or ibenta sya pagkatapos ipagawa.
    Grabe hinayang na hinayang ako sa eg na to kung ibebenta ko nga sya.... dahil kung mababasa nyu po ang mga pinalitan ko sa unang post ko sa thread na to eh talaga ginastusan ko sya.Kulang 30t na ang mga accesories at mga engine parts na nagastus ko pagkatapos ang resulta eh FAILURE.
    Aug 2005
    Sir, if ever na okey tlaga mekaniko mo and naiintindhan nya ito pgawa mo ng mlaman ntin kung may defective na sensor or san ka magffocus na problem. if ever DIY ka mski kaw Kya mo na gawin yan
    Way to check codes on your civic (EF, EG, EK, Gen-1 CRV).
    If you go to passanger side kick panel and raise up the carpet u sould see your ecu.
    and above your ECU there will be a plug. It has 2 wires coming out of it.
    I take a spare piece of thin speaker wire and cut off both ends so that the actual
    copper of the wire is showion on both ends. i twist up both ends so that they are in
    a nice point. stick one end of the wire into the first socket on the plug. The other
    end of the wire into the other socket.
    Turn your key to the ON position.. dont start your car. just to the ON position.
    Watch your check engine light on your cluster. it will flash.. 1 long flash is 10.
    the quick flashes are one. so if ur CEL goes !.....!!! that is a
    code 13. !....!....!!!!! code 25. then take the code #'s and hop on this thread
    and see what it is.
    1 O2A - Oxygen sensor #1
    2 O2B - Oxygen sensor #2
    3 MAP - manifold absolute pressure sensor
    4 CKP - crank position sensor
    5 MAP - manifold absolute pressure sensor
    6 ECT - water temperature sensor
    7 TPS - throttle position sensor
    8 TDC - top dead centre sensor
    9 CYP - cylinder sensor
    10 IAT - intake air temperature sensor
    12 EGR - exhaust gas recirculation lift valve
    13 BARO - atmospheric pressure sensor
    14 IAC (EACV) - idle air control valve
    15 Ignition output signal
    16 Fuel injectors
    17 VSS - speed sensor
    19 Automatic transmission lockup control valve
    20 Electrical load detector
    21 VTEC spool solenoid valve
    22 VTEC pressure valve
    23 Knock sensor
    30 Automatic transmission A signal
    31 Automatic transmission B signal
    36 traction control found on JDM ecu's
    41 Primary oxygen sensor heater
    43 Fuel supply system
    45 Fuel system too rich or lean
    48 LAF - lean air fuel sensor
    54 CKF - crank fluctuation sensor
    58 TDC sensor #2
    61 Primary oxygen sensor
    63 Secondary oxygen sensor
    65 Secondary oxygen sensor heater
    71 random misfire cylinder 1
    72 random misfire cylinder 2
    73 random misfire cylinder 3
    74 random misfire cylinder 4
    80 Exhaust Gas Recirculation insufficient flow detected
    86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
    90 Evaporative Emission Control System leak detected in the fuel tank area
    91 Fuel Tank Pressure Sensor low input
    92 Evaporative Emission Control System insufficient purge flow
    dko ko lang mupload ung image ng cmputer box wire socket, try to visit Honda Club forums dun gling yan
    wow boss joey,meron palang ganitong code pa ang ECU ng honda..
    Thank you bossing!
    Sep 2006
    you can get the service manual from HCP... yun din un gamit sa casa.kumpleto lahat bawat sulok ng car mo ipapakita... pati mga screws etc
    Aug 2005
    Quote Originally Posted by kedrian View Post
    Thank you bossing!
    welcome sir!
    Jun 2004
    I am not familiar with the engine of your car, but in my case before nung medyo bumabagsak yung idle (esp. during braking) nde lang maayos yung adjustment ng valve tappets. Kung may Idle air control valve (IACV) yan pacheck mo na rin.
    Parang medyo mahal rin yata inabot at ang daming pinalitan... presyong engine swap na halos...
    Sir yung IACV napalitan na din po yun ng surplus unit.(refer to my 1st post).
    Nalinis at napagana naman ng maayus until nung pinalitan na ang mga pyesa (refer to my 1st post)..
    Simula nun lagi ng erratic iddling ako tuwing 1st start.Tapos nababawasan sya pag napaiinit mo ng mabuti ang makina..Ganun pa man hindi pa din smooth at komportable ang takbo.
    Ginawa ko na din po ang RESETING OF ECU (computer box).Nabawasan pero ganun pa din..Bukas po ng umaaga idadaan ko na sa HONDA CASA quezon ave.Pag hindi po kinaya = 4 sale na sya.
    Thanks po sa advice bossing.
    Just got back from HONDA Casa Quezon ave.
    Bukas pa daw makukuha so iniwan ko na..6:30am andun na agad ako..inagahan ko na talaga.
    Meron po ako nakausap na Customer ...He said that he have the same problem regarding my situation recently and fix it there na din in HONDA CASA.He said that its the SERVO that needs to be fix in able to smoothen the ride.Tama po ba sya??
    Anu po ang SERVO??Saan po ito banda` makikita??
civic ESi `94MdL engine problem.
