Results 1 to 15 of 15
    Hi, i was wondering if someone would be able to help me..
    i just had my 5,000km checkup/change oil (first change oil) (chery does no do oil change by 1,000km) yesterday...
    based on what i know, i was under the impression na kapag 1st oil change, eh may mga kailangang i adjust sa engine, like ung mga pistons na kailangang higpitan, due to the break in period which is finally over..
    i was surprised because they did not adjust anything on the engine.. sabi sa akin ng lead mechanic sa casa, hindi na daw kailangan mag adjust ng mga valves sa engine, dahil ok na daw un, talagang change oil lang ang dapat gawin..
    sabi din nila kahit daw ung vios, di na daw dapat mag adjust sa engine .. honda cars lang daw and inaadjust..
    totoo ba un? as in change oil lang ang ginawa sa car ko? hinigpitan lang nila ung mga bolts sa under chassis, and that was it...?
    ^^actually it depends on the car. could be true.
    Sep 2008
    had my Sentra undergo 5K PMS last Saturday sa Nissan Gallery - Libis
    they used Consult on my engine, and when all checked clean, no adjustments were made as well.
    My friend had his Lancer undergo 5K PMS last month, la ren inadjust ang Diamond Motors..
    More likely, same ren for your Chery.
    sa mga brand new cars namin oil change lang din and some filters ....
    Sep 2004
    Huh? Ngayon ko lang narinig na tuwing 5k PMS eh may ina-adjust sa makina. And you don't tighten pistons, hindi naman kasi sila parang bolt na pwedeng higpitan. And for the mechanic to do that, kailangan pa niyang buksan ang makina.
    Pag kailangang buksan ang makina tuwing ika-1st oil change, that must be one lousy engine.
    Aug 2005
    Quote Originally Posted by Galactus View Post
    Maybe the TS was referring to valve clearance adjustments na dati talaga kasama sa 1k pms routine. ewan ko lang ngaun
    Thanx a lot sa mga nagreply.. at least im convinced na there's nothing wrong sa 1st oil change ko
    Aug 2006
    That's why newer engines are called VVT-i, CVT, VTi etc..etc, they have variable valve that is self adjusting already coupled with Intelligent ECU . Ignition system are also electronics that does not need adjustment.
    In newer Toyota's, there's a metal plate inside the hood that says "No adjustment needed".
    [quote=Mile2;1201076]That's why newer engines are called VVT-i, CVT, VTi etc..etc, [quote]
    i agree.
    sir, just a minor correction, i think cvt refers to the transmission. if what you meant is the variable valve timing of mitsubishi, then it's mivec (Mitsubishi Innovative Valve timing Electronic Control system)
Chery QQ 1.1MT.. 5,000km Change oil..
