Results 11 to 15 of 15
February 18th, 2009 10:16 PM #11
February 19th, 2009 12:07 AM #12
- 19
February 22nd, 2009 12:16 AM #13Thanx a lot sa mga nagreply.. at least im convinced na there's nothing wrong sa 1st oil change ko
February 22nd, 2009 01:23 PM #14
That's why newer engines are called VVT-i, CVT, VTi etc..etc, they have variable valve that is self adjusting already coupled with Intelligent ECU . Ignition system are also electronics that does not need adjustment.
In newer Toyota's, there's a metal plate inside the hood that says "No adjustment needed".
- Nov 2008
- 65
February 26th, 2009 04:42 PM #15[quote=Mile2;1201076]That's why newer engines are called VVT-i, CVT, VTi etc..etc, [quote]
i agree.
sir, just a minor correction, i think cvt refers to the transmission. if what you meant is the variable valve timing of mitsubishi, then it's mivec (Mitsubishi Innovative Valve timing Electronic Control system)
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
