Magkano po kaya ang aabutin kapag nagpachange-oil ako? And suggestions naman po saan maganda magpachange-oil. Newbie po ako sa ganitong bagay. Thanks in advance..
What's the model and mileage of your car? What area are you from? That can help others give you suggestions.
A servitek station is one place to start. There are also shops like Speedyfix, etc.
Buy your oil and oil filter from casa and make sure to also purchase a new crush washer for the drain plug. The crush washer is single-use part that should be replaced once removed.
Go to a Servitek station and just pay for labor. The Servitek on Congressional Ave. charges me just P150.
My car is Toyota Camry model 2000.
My area is Dasmarinas Cavite.
any suggestion po saan magandang shop near my area? Thanks.
Any idea kung magkano po aabutin ko all in all? Thanks..
What's your mileage and when was the last time you had your transmission oil changed? Is the shifting still smooth?
Im confused.
TS. What job do you want done in your car?
An "engine" oil change?
Or a "transmission" oil change?
